Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Data movement per kernel
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Data movement per kernel
  • Date: Wed, 27 Feb 2019 16:03:07 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sameh.abdulah@kaust.edu.sa; spf=Pass smtp.mailfrom=sameh.abdulah@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f44.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks, Samuel for your reply. Actually, I solved my problem and I do not
need this data movement calculation for now. However, I think it will be a
useful tool for the other users.
Thanks,
Note: please ignore the pervious message with the link.
.-Sameh
On 2/26/19, 6:25 PM, "Samuel Thibault" <samuel.thibault@inria.fr> wrote:
Hello,
Sameh Abdulah, le mer. 20 févr. 2019 09:55:06 +0300, a ecrit:
> My question is: Is there any way to estimate the data movement cost per
kernel?
> STARPU_COMM_STATS estimates the data movement cost per computing node
which
> helped us to investigate the problem but not to understand the reason
behind
> it.
Mmm, there currently isn't.
We could implement this inside starpu-mpi by accounting the movements
within the codelet structure, and let you access the information from
there.
Samuel
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
Haut de le page
