Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed.
- Date: Tue, 26 Mar 2019 23:46:07 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f54.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear Samuel and Starpu-dev,
I am facing an error at the initilization step of StarPU. The error is: core/perfmodel/perfmodel_bus.c:598: find_cpu_from_numa_node: Assertion `current' failed.
raise () from /lib64/libc.so.6
abort () from /lib64/libc.so.6
in __assert_fail_base () from /lib64/libc.so.6
in __assert_fail () from /lib64/libc.so.6
in find_cpu_from_numa_node (obj=0x49a5b7f0) at core/perfmodel/perfmodel_bus.c:598
in measure_bandwidth_between_numa_nodes_and_dev (dev=0, dev_timing_per_numanode=0x200000357338 <cudadev_timing_per_numa>, type=0x20000030cf50 "CUDA") at core/perfmodel/perfmodel_bus.c:633
in measure_bandwidth_between_host_and_dev (dev=0, dev_timing_per_numa=0x200000357338 <cudadev_timing_per_numa>, type=0x20000030cf50 "CUDA") at core/perfmodel/perfmodel_bus.c:654
in benchmark_all_gpu_devices () at core/perfmodel/perfmodel_bus.c:784
in generate_bus_affinity_file () at core/perfmodel/perfmodel_bus.c:1029
in _starpu_bus_force_sampling () at core/perfmodel/perfmodel_bus.c:2931
in check_bus_config_file () at core/perfmodel/perfmodel_bus.c:2036
in _starpu_load_bus_performance_files () at core/perfmodel/perfmodel_bus.c:2959
in starpu_initialize (user_conf=0x490f02b0, argc=0x0, argv=0x0) at core/workers.c:1400
in starpu_init (user_conf=0x490f02b0) at core/workers.c:1213
How can I solve it? Is it connected with hwloc?
Many thanks,
Amani
- [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Amani Alonazi, 26/03/2019
- Re: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Brice Goglin, 26/03/2019
- Re: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Amani Alonazi, 26/03/2019
- Re: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Amani Alonazi, 27/03/2019
- Re: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Samuel Thibault, 29/03/2019
- Re: [Starpu-devel] Error find_cpu_from_numa_node: Assertion `current' failed., Amani Alonazi, 29/03/2019
