Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Second release candidate for StarPU v1.3.0 available
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-announce@lists.gforge.inria.fr
  • Cc: POINT Gérald <Gerald.Point@labri.fr>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
  • Subject: [Starpu-devel] Second release candidate for StarPU v1.3.0 available
  • Date: Mon, 18 Mar 2019 16:36:42 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-data: A9a23:4mP/lq66oEeX7XmfUGE2fgxR2vbMJQPm6Rkv2y7L/r5q3AbuRmh08W 0qbcF3xqo6F80zJSFUta0rQj2kOntoghqBCeDXWzdjCZtrkPcIT6XaE3UVOt5zJ2MuGgYhFy aa1uHn5rOYEhri1CaOmZWycVw/2hCulFE7UE7lGs2y48S6N4N4XPfSG7Y3luHsEJDJaKpq2x TFjKqOuzJDwIjUzFt9ZADEusdHHoTZe2PfjhFQ6K90pLB15Fnzj8ORXAtbRg1Fn4uW0GEfzF pC+J9lFolAFjabUbJRU2L5Jb9RssFelYX3TSNd8svDz33IBqF3Fa5ZFth5K7hXLdlpkXTDD7 OsRvqiVOZy6x0qZnhMtm8inqb/+IEkFozfGcYXMv/zCOPDoP9oCyZj8ssO14XHcrER4F/WZ3 fGz06CsYP+kdaX2O1bPPTA6+5qQk1YLhzBb7736wHRuQyF0WmGzMkYUfKCM9UjGPcC597+NI G8SYrajb06AmPK2v47L0wGTVyv6kM8KO0YiMsu9rgAv5NuUlDc3JHq92chFvnhECXqqwvIO5 OZwiP4bkn9LZ+kfdBQQ/3xVPbpJMDFNbe0pvSEbQA+Qb+kMpppcu8qIx5ZqHk0Mi/YnjBe4i XclIj4LgS0Qb6ilUB8O68CGC6EgkQf+jx+R5LPVoSsJYIAjdDJoiU77RoJUNUGdNDQ1wUlXz UPCDBpjC1NYUQX61RH9HEAAXGsRLQ27tQ3KDpY8o2ZfkN3BdYk2YVeZYH07VhyeihFbrUiZH DmFnf4yiC5WNs6U8YpKMkb9dRorJrOmKkWKAMzCT0V7t7VPRM+sire7OkEvgyZpfn9YqEphC z6RDU23/0mdercGzLiQAqfL6Y3eeKNrr9lffkXQ5puzZ76Ey5LQYPqN+Tv1bM5qZiB6BtOkR FMg8ApT5pvhhjWnwU82jhG4u2vK6jXNvSbc1EqRkwnjIbqzJfrlEk=
  • Ironport-phdr: 9a23:SinqdxwWl5vayqPXCy+O+j09IxM/srCxBDY+r6Qd0uoWKfad9pjvdH bS+e9qxAeQG9mCs7Qc0qL/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFc VGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pHOfwlEniaxba5vJx iqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UK dXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7Vq4/Vyi84K h3SR/okCYHOCA/8GHLkcx7kaZXrAu8qxBj34LYZYeYP+d8cKzAZ9MXXXdPUMZPWSxPAY2yYY UAAOUDMulEoIfwvEcOoBikCAWwGO/ixD1Fi3nr1qM6yeQhFgTG0RQ4Ed0UrHTUrM/6NKMTUe +r0aLGzSjDb+lT2Tjj7ojIbhchquyLULJ2a8XR1UkvGBnBjlWRt4PpJT2V1vkXs2ie8eVgU/ 6vi2k8pgF1uDeg3d0siojTioIb0FDJ7CN0y5s7K92/TU50e9+kEJ1IuiGbMYt2WMIiTHtytC Y00L0KoZq7czIRx5Q9xh7TcfKHc5KO7xn+V+iROS91iG9qdb+9nRq+71WsxvHmWsWqzVpHrj BJn9rCu3wVyhDe7saKRuF980u9wzqDyh3f5v1eLUwplafXNZgsyaMqmJUJq0TMBCr2lV32jK CIckUk/fCl6/r+brTnp5+cMop0ih3kPagylMGzG/k4PhEVUGic4+SzyaPs8lfkQLRFlPE2nL PZvIjbJcQduKG5HxdY3pss5hu9FTuqzskUkWUdIF5bZR6Kj5LlNlLALfzgCPewmVWskDNlx/ DcOb3hB43ALn7Zn7f9fbZy8UpcyAstwtxF6ZJUF6sBIPftVU/3qNzYCQQ0MwiuzOn8EtV915 kSWWyVAqOBKqPdrUeI5v4zI+mLfIIVoyr9JOI/5/72kH81gEUSfa+v3ZsQdXC4GOhpLFuCbH rog9cBCnsKvhEkQOzlhl2CViRTZ3msUK4m5zE7DpimDYbZSYy3jryBxj+xHodKaWBeFlCMDX Doep2fW/cQci2SONdhkiEdWbe8VYAhyw+htAvhxrpjL+rU4TEYtYn52Nh66e3Tkgsy9TNqAM iH0mGNSXt0nmISSDMs0qB/ux819lDWyrRxmeRFUNVV4fRUVAw3HZrd1PBhTd/8XRjOc5GITk ynS5OoG2IfVNU0lvkHf0Z0H9Svxj7exS+nBaMS3+iNDYA0+6bd0j7/Otx4xnDa04ElhlM8Q4 1BLzv11eZE6wHPCtuRwA2inKGwePFZhXaVrTrR/S+1pEhdFTVIf+DFUHQYPBWEs5Hr50bHU7 b2UvI6dwFG08KPI7ZaLNPz3w0fGKXTfe/Gamf0oF+eQA6Sz+rUPo7jcX8cmivHWhBdwlIjuE 2ePA17PR+P5mfXDThgD1XqOhu+9eB0snL9QFVmlgw=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
The second release candidate for 1.3.0 is available.
Along with a bunch of bug fixes, here the changes since the first rc :
* New schedulers modular-pheft, modular-prandom and modular-prandom-prio
* Add STARPU_MATRIX_SET_NX/NY/LD and STARPU_VECTOR_SET_NX to change a
matrix tile or vector size without reallocating the buffer.
* Application can change the allocation used by StarPU with
starpu_malloc_set_hooks()
* XML output for starpu_perfmodel_display and
starpu_perfmodel_dump_xml()   function
* New tool starpu_mpi_comm_trace.py to draw heatmap of MPI communications
* Support for ARM performance libraries
* Add functionality to disable signal catching either through field
starpu_conf::catch_signals or through the environment variable
STARPU_CATCH_SIGNALS
* Support for OpenMP Taskloop directive
Files can be found at the usual locations (see below)
Cheers,
Nathalie
On 06/02/2019 11:53, Nathalie Furmento wrote:
> All,
> The StarPU team is really pleased to announce the first release
> candidate for StarPU 1.3.0 !
> The 1.3 release serie brings among other functionalities a MPI
> master-slave support, a tool to replay execution through SimGrid, a HDF5
> implementation of the Out-of-core, a new implementation of StarPU-MPI on
> top of NewMadeleine, implicit support for asynchronous partition
> planning, a resource management module to share processor cores and
> accelerator devices with other parallel runtime systems, ...
> You can find more detailed informations at
> https://gforge.inria.fr/frs/?view=shownotes&group_id=1570&release_id=10674
> or in the documentation
> http://starpu.gforge.inria.fr/files/starpu-1.3.0rc1/html/
> The tarball along with the md5sum file and the OpenPGP signature are
> available as usual on the starpu web site
> or directly on the Gforge web site
> https://gforge.inria.fr/frs/?group_id=1570
> Nathalie, for the StarPU team.
Dr Nathalie Furmento Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
  • [Starpu-devel] Second release candidate for StarPU v1.3.0 available, Nathalie Furmento, 18/03/2019
Haut de le page
