Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] infinite loop if HOME not defined
Archives de la liste
Chronologique Discussions
  • To: Florent Pruvost <florent.pruvost@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] infinite loop if HOME not defined
  • Date: Thu, 9 Jan 2020 15:26:05 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Florent Pruvost, le jeu. 19 déc. 2019 16:59:06 +0100, a ecrit:
> For info. there is a bug with an inifinite loop when HOME env. var. does not
> exist.
I couldn't reproduce the issue either, but found the loop between
> #18705 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at
> common/utils.c:104
> #18706 0x00007fe2160b14c8 in _starpu_mkpath (s=<optimized out>, mode=448) at
> common/utils.c:104
and commited a fix to master and 1.3
Samuel
  • Re: [Starpu-devel] infinite loop if HOME not defined, Samuel Thibault, 09/01/2020
Haut de le page
