Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU changeable sizes and StarPU purge
Archives de la liste
Chronologique Discussions
  • To: Rabab Al-omairy <rabab.omairy@kaust.edu.sa>
  • Cc: starpu-devel@lists.gforge.inria.fr, "hatem.ltaief" <Hatem.Ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] StarPU changeable sizes and StarPU purge
  • Date: Thu, 9 Jan 2020 18:51:46 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Rabab Al-omairy, le dim. 01 déc. 2019 22:03:43 +0300, a ecrit:
> after matrix compression each tile ends up having different sizes.
> However, on distributed memory on which tiles are 2D cyclically
> distributed among mpi nodes I have  the following error:
> [1][starpu_mpi][_starpu_mpi_test_detached_requests][assert failure] MPI_Test
> returning MPI_ERR_TRUNCATE: message truncated
Mmm, indeed, the distributed support for matrices was not extended to
support tiles with varying size. Here the receiver is expecting a full
size since it doesn't know the size is smaller.
I have added some experimental support in the master. In order to try it
you need to uncomment the //#define DYNAMIC_MATRICES in both
src/datawizard/interfaces/matrix_interface.c and mpi/src/starpu_mpi_datatype.c
That is however for now incompatible with OOC support with O_DIRECT
enabled.
> For some matrix size which I can say matrix with medium size, I
> have the following message which cause application to stuck and not continue
> execution.
> [starpu][starpu_memchunk_tidy] Low memory left on node RAM 0 (6405MiB over
> 128808MiB).
So StarPU is lacking memory. Do you have OOC enabled?
Samuel
Haut de le page
