Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Problem with performance model calibration
Veuillez patienter...
starpu-devel@inria.fr
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Problem with performance model calibration
  • Date: Wed, 20 May 2020 17:17:25 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: Umeå University / HPC2N
Hi,
On 2020-05-20 17:13, Mirko Myllykoski wrote:
The flop count is 2 * M^2*N (M X M times M X N matrix multiplication). The M*N factor is related to copy operation. You can find MRM calibration files from [2]. The main problem with MRMs is that I get some speedup with linear models but MRM models seem to make the code slower when GPUs are used. Also, the models [2] look wrong (negative coefficients).
The MRM calibration files [2] are older (StarPU 1.3.3).
- Mirko
Mirko Myllykoski, Ph.D.
Senior research engineer, Department of Computing Science
Application expert, HPC2N
Umeå University
By sending an email to Umeå University, the University processes your personal data. For more information, please read: https://www.umu.se/en/gdpr
Haut de le page
