Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Problem with performance model calibration
- Date: Wed, 20 May 2020 18:25:39 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: Umeå University / HPC2N
Hi,
On 2020-05-20 17:39, Samuel Thibault wrote:
More precisely, that it didn't compute the non-linear model. (the linear
one is always computed since it's easy). Perhaps check how that happens
for tests/perfmodels/non_linear_regression_based.c vs how that doesn't
seem to happen with your application. Normally that happens during
starpu_shutdown in _starpu_deinitialize_registered_performance_models,
in dump_reg_model that calls _starpu_regression_non_linear_power.
I experimented with non-linear models and my code indeed calibrates the non-linear models for some tasks. I am assuming that the GEMM tasks are simply too noisy. Is this plausible? I tried to calibrate the non-linear models on my desktop machine without GPUs and the GEMM tasks calibration still failed.
I will try to figure out why the GEMM tasks are so noisy. I think matrix-matrix multiplication should behave quite predictability.
- Mirko
Mirko Myllykoski, Ph.D.
Senior research engineer, Department of Computing Science
Application expert, HPC2N
Umeå University
By sending an email to Umeå University, the University processes your personal data. For more information, please read: https://www.umu.se/en/gdpr
- [Starpu-devel] Problem with performance model calibration, Mirko Myllykoski, 18/05/2020
- Re: [Starpu-devel] Problem with performance model calibration, Samuel Thibault, 20/05/2020
- Re: [Starpu-devel] Problem with performance model calibration, Mirko Myllykoski, 20/05/2020
