Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Problem with performance model calibration
- Date: Mon, 1 Jun 2020 13:55:36 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: Umeå University / HPC2N
Hi,
On 2020-05-20 19:04, Samuel Thibault wrote:
No, the shape seems relatively nice enough. But perhaps put printfs in
the loop of _starpu_regression_non_linear_power to check that it does
get called and whether it perhaps diverges to nan.
I investigated the _starpu_regression_non_linear_power function. It appears that some list entities (1st argument) are invalid in the sense that the "mean" field is 0.0. This causes a situation where "cmax" becomes zero and NaNs follow...
I modified the find_list_size and dump_list functions so that the invalid list entries are ignored. This fixes the fitting problem. However, I am somewhat concerned over the fact that some of the ignored list entities correspond tasks that are not that small. Could there be something wrong with the time measurement?
- Mirko
Mirko Myllykoski, Ph.D.
Senior research engineer, Department of Computing Science
Application expert, HPC2N
Umeå University
By sending an email to Umeå University, the University processes your personal data. For more information, please read: https://www.umu.se/en/gdpr
- Re: [Starpu-devel] Problem with performance model calibration, Mirko Myllykoski, 01/06/2020
- Re: [Starpu-devel] Problem with performance model calibration, Samuel Thibault, 03/06/2020
- Re: [Starpu-devel] Problem with performance model calibration, Mirko Myllykoski, 05/06/2020
- Re: [Starpu-devel] Problem with performance model calibration, Samuel Thibault, 05/06/2020
- Re: [Starpu-devel] Problem with performance model calibration, Mirko Myllykoski, 09/06/2020
- Re: [Starpu-devel] Problem with performance model calibration, Samuel Thibault, 09/06/2020
