Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Problem with performance model calibration
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Problem with performance model calibration
  • Date: Fri, 5 Jun 2020 13:20:10 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: Umeå University / HPC2N
Hi,
On 2020-06-03 20:41, Samuel Thibault wrote:
Ok. When that happens, what are the values of the other fields? We have
some code that tries to get rid of outliers, which just flushes the
content of the entry, in which case the mean will indeed be reset to
0.0, but also all other values (sum, sum2, nsample).
It appears that most of other field are zero:
$1 = {mean = 0, deviation = 0, sum = 0, sum2 = 0, nsample = 0, nerror = 0, footprint = 3995150445, size = 31433, flops = 62866,
duration = 0, tag = 0, parameters = 0x0}
$2 = {mean = 0, deviation = 0, sum = 0, sum2 = 0, nsample = 0, nerror = 0, footprint = 3929775567, size = 11492, flops = 22984,
$3 = {mean = 0, deviation = 0, sum = 0, sum2 = 0, nsample = 0, nerror = 0, footprint = 1444706215, size = 14400, flops = 28800,
$4 = {mean = 0, deviation = 0, sum = 0, sum2 = 0, nsample = 0, nerror = 0, footprint = 1856779794, size = 60000, flops = 120000,
I was simply looking at the size and mean fields...
I checked and I could not detect any entries with nsample != 0 and mean == 0.0.
Am I understanding correctly that these mean == 0.0 entries are the result of a cleanup performed before the models gets calibrate?
- Mirko
Mirko Myllykoski, Ph.D.
Senior research engineer, Department of Computing Science
Application expert, HPC2N
Umeå University
By sending an email to Umeå University, the University processes your personal data. For more information, please read: https://www.umu.se/en/gdpr
Haut de le page
