Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Problem with performance model calibration
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Problem with performance model calibration
  • Date: Tue, 9 Jun 2020 21:24:41 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Mirko Myllykoski, le mar. 09 juin 2020 13:54:25 +0200, a ecrit:
> That is going to cause problems due to the log(y[i]-c) statement in the
> test_r, compute_b and compute_a functions (negative argument for log).
Oh, right!
Actually, these values shouldn't be taking into account in the linear
regression being the non-linear regression: we are regressing y[i]-c,
not y[i], and that difference will *not* get smaller.
I have fixed this and other issues in the different branches:
- ignore the values close to c
- start from the first fourth of the values, instead of the minimum
- weight the values by their number of measurements, otherwise you'd get
disturbed by small outliers.
Could you try that with your application? I believe the result should
be much better.
Samuel
Haut de le page
