Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Problem with performance model calibration
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Problem with performance model calibration
  • Date: Tue, 9 Jun 2020 13:16:05 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Mirko Myllykoski, le mar. 09 juin 2020 12:44:00 +0200, a ecrit:
> In particular, you can see that the "c" parameter is quite small for the
> CUDA implementation:
Indeed, and also for the CPU case c is bogus, even if to a lesser
extent. Looking at _starpu_regression_non_linear_power, I see that it
starts its dichotomy for c in [0, min(averages)]. But with the noisy
results that you have, taking the minimum is not a good idea: e.g. in
the CUDA case the minimum average is around 0.004-0.005, but only a few
of the averages have this value. Taking the minimum was meant to make
the dichotomy faster, but with noisy data it doesn't seem like a good
idea. We still need some initial maximum value for the dichotomy, but we
could use the maximum average, or even a coefficiented average of the
average.
Could you give a try to converting find_list_min into find_list_max, and
using that for the initial value of cmax?
Samuel
Haut de le page
