Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Task Bench paper accepted
Archives de la liste
Chronologique Discussions
  • From: Elliott Slaughter <slaughter@cs.stanford.edu>
  • To: starpu-devel@lists.gforge.inria.fr, "Wu, Wei" <wwu@lanl.gov>
  • Subject: [Starpu-devel] Task Bench paper accepted
  • Date: Tue, 30 Jun 2020 12:58:27 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=slaughter@cs.stanford.edu; spf=Pass smtp.mailfrom=slaughter@cs.stanford.edu; spf=None smtp.helo=postmaster@smtp2.cs.Stanford.EDU
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi all,
It's been a while so I'm not sure if you remember, but we wrote a benchmark for distributed system performance, where we included results for StarPU. I wanted to let you know that the paper has been accepted to be published in SC20. That means we have about a 2 month window to update results for the camera ready paper.
I'm not aware of any outstanding performance issues with the StarPU implementation, but I just wanted to close the loop and make sure that you had a chance to see the paper one more time and make sure things look ok. We still have the ability to run experiments if there's anything we should try that might improve the performance.
Thanks and let us know if you have any comments.
Elliott Slaughter
"Don't worry about what anybody else is going to do. The best way to predict the future is to invent it." - Alan Kay
Attachment: task_bench.pdf
Description: Adobe PDF document
Haut de le page
