Archives de la liste
Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
Chronologique Discussions
- To: Ludovic Courtes <ludovic.courtes@inria.fr>
- Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM
- Date: Thu, 27 Aug 2020 11:23:26 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Thanks Florent for the suggestion.
> Carrément, ou simplement rajouter fxt à « starpu-simgrid » si c’est pas
> utile d’avoir les deux variantes.
Good idea, Ludo. Indeed, in the starpu-simgrid case, the fxt overhead is much
less critical than in the actual starpu case, and it might not be worth
maintaining two separate guix packages.
Maybe the only point is to make sure the user is aware that fxt is around so
that he / she thinks to play with the STARPU_FXT_TRACE environment variable
( https://files.inria.fr/starpu/doc/html/OfflinePerformanceTools.html )
in order to disable them at runtime. One way to make sure the user is aware
of that is to name the (guix) package accordingly, for instance
starpu-simgrid-fxt . This would be consistent with the starpu-fxt package
naming. (And there would not be a starpu-simgrid (guix) package anymore.)
Best regards,
Manu
- [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Mathieu Verite, 18/08/2020
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Samuel Thibault, 18/08/2020
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Philippe SWARTVAGHER, 19/08/2020
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Florent Pruvost, 26/08/2020
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Ludovic Courtès, 27/08/2020
- Re: [Starpu-devel] StarPU : impossible de compiler avec SimGrid, MPI et Fxt sur PlaFRIM, Emmanuel Agullo, 27/08/2020
