Archives de la liste
- To: Vinícius Garcia Pinto <vgpinto@inf.ufrgs.br>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] How to visualize StarPU data?
- Date: Thu, 18 Feb 2021 00:35:59 +0100
- Organization: I am not organized
Hello,
Vinícius Garcia Pinto, le mer. 17 févr. 2021 16:12:54 -0300, a ecrit:
> - starvz is now on the CRAN repository
> (https://cran.r-project.org/web/packages/starvz/), one can install it with
> R> install.packages("starvz")
Oh, cool! Could you submit an update of the documentation on
https://files.inria.fr/starpu/doc/html/OfflinePerformanceTools.html#starvz
> # Get the path of starvz tools (to convert from fxt to paje and then
> to the CSVs expected by starvz)
> export STARVZ_TOOLS=$(Rscript -e 'cat(system.file("tools/", package
> = "starvz"), sep="\n")')
I would say the documentation should advise to add this to .bashrc, and
add $STARVZ_TOOLS to $PATH there too, so that the user just needs to run
starvz at his prompt.
> # Run starvz (assuming you have |starpu_fxt_tool|, |pj_dump|, and
> |rec2csv| in |$PATH|)
> $STARVZ_TOOLS/starvz /foo/path-to-fxt-files
Could starvz optionally directly take a paje.trace file instead of an
fxt file? fxt files are not portable across versions of starpu.
> # Done! you should find a starvz.png file at /foo/path-to-fxt-files
Great :)
Is there an option to generate a "movie" of the matrix tiles
loads/evictions? That would help us with scheduling under memory
constraints.
> If you want to have more control over the starvz panels, enrichments,
> disable plots, etc, you can jump to an R session and play with the config
> and plot functions. We have a working paper where we discuss each function's
> usage (https://hal.inria.fr/hal-02960848/document), we are still working on
> publishing it, but the main steps are already there...
You could like that paper from the StarPU documentation as well :)
Samuel
- [starpu-devel] How to visualize StarPU data?, Sangeeth Simon, 17/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Philippe SWARTVAGHER, 17/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Vinícius Garcia Pinto, 17/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Samuel Thibault, 18/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Vinícius Garcia Pinto, 18/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Samuel Thibault, 22/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Lucas Leandro Nesi, 18/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Lucas Leandro Nesi, 19/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Samuel Thibault, 23/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Sangeeth Simon, 18/02/2021
- Re: [starpu-devel] How to visualize StarPU data?, Sangeeth Simon, 24/02/2021
