Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] How to visualize StarPU data?
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] How to visualize StarPU data?
  • Date: Thu, 18 Feb 2021 10:11:59 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sangeethsimon2@gmail.com; spf=Pass smtp.mailfrom=sangeethsimon2@gmail.com; spf=None smtp.helo=postmaster@mail-yb1-f171.google.com
  • Ironport-phdr: 9a23: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
Bonjour Samuel,
Here is my attempt that exposes the exact problem of incompatibility between Paje.Trace and Vite.
1. Launched my vite (version 1.2 July 2010) with the trace file paje.trace (attached with this email) that I generated using FXT in a task scheduler called StarPU. I get figure 1 (attached)
2. Preferences-> settings->states and I get figure 2 (attached). As you can see, by default, all states are active with ticks against the colors in them.
3. Since my objective is to only visualize the 7th task (intResidual), I have unchecked all other color boxes and select 'apply' (figure 3).
4. Now, I click on the refresh button and I still do not see intResidual being shown exclusively in the chart (figure 4).
So in a nutshell, the color-based filtering of states is not working.
Am I missing something at my end?
Also, please comment on StarVZ toolkit (of which you were an author if I am not wrong?). Does it help derive more information from StarPU trace? Is it much more powerful than say vite in terms of Gantt charts? Is the learning curve too steep for a domain expert like me?
Kindly advise.
Merci Beaucoup.
On Thu, Feb 18, 2021 at 4:46 AM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Sangeeth Simon, le mer. 17 févr. 2021 08:21:36 +0100, a ecrit:
> I am working with team CAGIRE where we are trying to employ StarPU on Finite
> Volume type CFD code for nonlinear hyperbolic conservation laws. We have had
> some initial [1]success with our work.
Interesting!
> 1. The Paje.trace file generated by StarPU fxt is not wholly supported by Vite.
> By 'wholly supported' I mean that certain features like color-based sorting of
> tasks/states is not possible. As identified by one of the developers of Vite, '
> ... this is a know issue with StarPU trace.
Possibly not known to me :)
> They have multiple event with the same identifier,
Do you use scheduling contexts? If not, I'm not aware of an issue, would
you have a small reproducer?
> StarPU does not respect strictly the paje format,
Normally it does, we check this in the CI by running the output through
pjdump.
> Now, has there been any progress on getting this feature to work?
Without precise reports, we can't fix bugs :)
> 3. I have also heard about Paraver as a tool kit to visualize time data. Does
> StarPU fxt output data that can be read by Paraver?
There is no such support, but such a feature would be very welcome
indeed.
> 4. Are there any other graphical tools to visualize and analyze the scheduler
> behaviour (at the task and memory management level) that works for StarPU?
Normally they would be documented in the offline performance feedback of
the StarPU manual.
Samuel
Dr. Sangeeth Simon,
Post-Doctoral Researcher,
Team CAGIRE, INRIA,
Pau, Nouvelle-Aquitaine, France
Attachment: paje_4by4.trace
Description: Binary data
Attachment: Re [VIte] Issue with Color.zip
Description: Zip archive
Haut de le page
