Archives de la liste
- To: Alexis Montoison <alexis.montoison@polymtl.ca>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] StarPU and arm64
- Date: Tue, 27 Sep 2022 09:12:33 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Alexis Montoison, le mar. 27 sept. 2022 04:36:41 +0000, a ecrit:
> The log for the platform aarch64-linux-musl is available here:
> https://dev.azure.com/JuliaPackaging/Yggdrasil/_build/results?buildId=22480&view=logs&jobId=0e6a979a-5bf9-5a20-bd70-47d70d374d8d&j=c88e2ad8-0ae9-5016-62b7-92b49cf6917a&t=500245c9-b903-5a61-eeed-beaeb001072a
Ok, I don't see any odd flag in there, but I guess your build system is
using -mcmodel=tiny by default. StarPU is however larger than 1MB so you
need to use -mcmodel=small.
Samuel
- [starpu-devel] Tester StarPU dans Julia, Alexis Montoison, 23/09/2022
- Re: [starpu-devel] Tester StarPU dans Julia, Samuel Thibault, 26/09/2022
- Re: [starpu-devel] Tester StarPU dans Julia, Alexis Montoison, 27/09/2022
- Re: [starpu-devel] StarPU and arm64, Samuel Thibault, 27/09/2022
- Re: [starpu-devel] segfault in macox / windows, Samuel Thibault, 27/09/2022
