Accéder au contenu.
Menu Sympa
starpu-devel - [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@inria.fr
  • Subject: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error]
  • Date: Wed, 9 Oct 2024 15:50:59 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wr1-f43.google.com
  • Ironport-data: A9a23:Rp5ZfKswRnJ5GcmpK04OfvZLUOfnVJRfMUV32f8akzHdYApBsoF/q tZmKTrVOazfYmf1L9knO4qzoR8EsJ/XzIIyHgto+yA1FysagMeUXt7xwmXYb3rDdJWbJK5Ex 5xDMYeYdJhcolv0/ErF3m3J9CEkvU2wbuOgTrSCYEidfCc8IA85kxVvhuUltYBhhNm9Emult Mj7yyHlEAbNNwVcbCRNsspvlDs15K6u4WtA7wRkDRx2lAa2e0c9XMp3yZ6ZdCOQrrl8RoaSW +vFxbelyWLVlz9F5gSNz94X2mVTKlLjFVDmZkh+A8BOsTAezsAG6ZvXAdJHAathZ5plqPgqo DlFncTYpQ7EpcQgksxFO/VTO3kW0aGrZNYriJVw2CCe5xSuTpfi/xlhJHgpEocl1NowO311q 9c8DG8ISzOsn8vjldpXSsE07igiBMziPYdapWs5iD+FVrApRpfMR6iM7thdtNsyrpoWTLCOO oxDM2MpME+ojx5nYj/7DLo7lfepgz/2eTRcpVSWorQf7G3azQg327/oWDbQUoXaGpQNxR/G+ woq+UzkXAsTP4O+wwaayXGWiuzxvj7Sft07QejQGvlCxQf7KnYoIAYKXEGjvLy1h1CzX/pEO kkM82wvq7Iz/QqlVLHAswaQpXeFulsDQYMVHbFhrg6KzaXQ7kCSAW1soiN9VeHKffQeHVQCv mJlVfuzbdDCmOT9pa61nltVkd+zBcTRBWoLZCtBUhFcpte/+8c8iRXAStslG6mw5jEw9fcc3 BjSxBXSRZ1K5SLI60l/1V/CijOo4JPOS2bZIy3JC3m94FoRiJGNPuSVBJuy0RqEBImcR1iF+ nMDnqByKQzI4Y6lzESwfQnGIF1lCztp/tERbZ6D0qTNLwiQxkM=
  • Ironport-hdrordr: A9a23:mNDyz65+GhrVGnACcwPXwPPXdLJyesId70hD6qkRc202TiX8ra qTdZsgpHnJYVoqKRIdcK67Sc69qALnhPtICOAqVN/IPDUO0FHIEGgI1/qH/9SPIVyGygef78 tdmmpFZeEYwWIUsS+D2njBLz/o+re6zJw=
  • Ironport-phdr: A9a23:S1oTPx2K+/Jm0Hi2smDOzQ0yDhhOgF0UFjAc5pdvsb9SaKPrp82kY BeHo6821xSZB83y0LFttan/i+PaZSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQF cVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pDdfwlEniSxbL18I Rm5rgjdqNQdjJd/JKo21hbGrXxEdvhMy29vOVydgQv36N2q/J5k/SRQuvYh+NBFXK7nYak2T qFWASo/PWwt68LlqRfMTQ2U5nsBSWoWiQZHAxLE7B7hQJj8tDbxu/dn1ymbOc32Sq00WSin4 qx2RhLklDsLOjgk+2zRl8d+jr9UoAi5qhJ/34Hbb5ybOvlwcK3Det0XXnBOUtpUVyFbAoOwc 4kCAuwcNuhYtYn9oF4OoAO5Cwa2C+LvyzpIjWLq0KIhyeshFR/J3AojH9IJrnTfsdL4NKIIX uG6zanIyC/PYOlN1jjn7IjHbBYhofKLXbJuasfRxkwvGBnEjlWUs4DqIzSV1uEUvmWd8uFvW v6hhXQ9pAFtvjig2N0sio/Ri48R11zK+yp3zog6K9C6SkN3fcKoHYVOuyyUOYV6XswsT391t Ssm17ELpJy2cSwFxZk52hLSdvKKf5WI7B7+SeucJypzinxieLK6nRmy8E6gx/XmWcavyllKq jRKkt/PtnAKyRzf8NWHSvh780y82jiPzxje5v9YLU0wj6bWKJ4szqQumpYNrEjPBCD7lUvug KOLeEgo5vKk5/rob7jnvJOQKYB5hh/kPqgzhsCyB/kzPxYKX2iG4uS8yKPs/VfkTrVLj/w5j LHUvIzcKM8GvKC2GRVV3Zwm6xunDzepztAYnX4fIVJAYh2HjozpN0jAIfDiEPuzmlqsnThly vzcMb3hBZLNLnfHkLj/Z7py90lcyA8rwdBe4ZJbFK0BLertVkPtsNHUFBw0Pgyuz+r5Ftlxy 5kSVG2BD6OBNaPdq16I5uYhI+mWY48VvS7wK/0/6P/hjH85nEURcrOy0pQNbHC3APJmI0aeY XrymdoBHmIKsRA/TOzuklGNTTlTZ3OqU6I6/T40EJimApvbRoCxnLyB2z+2EoBOamBcFl+MC Wvod5mDW/oUcyKSPtVukiYcVbi8UoMuyA+htBHkxLpjNefU4S0ZtZf71Ndv/eHTlBcy9SZ1D 8uHyW2NQXt0zSs0QGotwKlluVE4xlqd3KxQgvpCFNUV6ekafB09MMv5xvx7DpjbUAvFc9GKT 0juFtCvETA0CNs7ytsDZUV6Bf2tixnC22yhBLpDxO/DP4A97q+Jhyu5HM160XuTjMHJ7nEjS 8pLbyi9g7JnshLUDMjPmlmYkKCjceId2jTM/SGN1znGp1lWBSh3V6iNRnUDfg3Ot92s40rST rroAL4uNgZHysmcAqRPY9zty15BQaSrI8zQNlq4gHz4HhOU3vWJZYvudX8a2XDYAVgFlkYa9 3+COA49ATmJrGfXDTgoHlXqMAv36ecrjnS9Qwcvyh2SKU1s073g4hkOmfmVUO8exJoBsSYl7 ipuRROzg4mQBN2HqA5sOq5bZLvR+X9h0mTU/0x4N52kdeV5g0IGNh5wtAXo3gl2DYNJlY4rq mkrxUx8M/DQ1lQJbD6e0Z3qX9+fYmDv4BCibbLX0VDCwZ6X/KkI8vExt1TkukmgCEMj93xt1 9Qd3WGb493GCw8bUJS5VUhSlVAyorjKYyx77ond0XBqMq6qmjDH0tMtQuAiz1fofttSNr+FC B6nC9cTVK3MYKQhn1mkaA5BPfgHrvZleZP7MaHcgej3Z7UF/nrul2lM7YFj31jZ8iN9TrSNx JMZ27SC2QDBUT7gjVCnu8SxmIZeZDhUEHDsrEqsTINXeKB2ep4GTGm0JMjijNB3l5/oHXdS/ VquAVABxuemfBOTaxr22ggahiF16TS33DC1yTB5iWRjq6OP3SmIyu7rcBcBOWlVbGZnhFboZ 4OzippJOSrgJxhsnxyj60HgwqFdr6kqNGjfT3BDeC3uJn1jWK+93labS/ZG84hg8SBeUeDmJ EufVqa4uRwRlSXqA2pZwjk/MTCsoJTw2RJg2iqRK3N6rXyRfs8Vp1+X4dXMRPsX1zAPQCR+i j7JLle5Ntitu96Tkt/Pv/u/WGSoSpBIOXOznMXQ6W3hvzQsXUb3luvW+JWvCQUg1C7ny9RmH T7FqhrxeMij1qi3N/5mYlg9AVb978RgHYQt2oA0hZwWxT0bnsDPpStBwTq1a48Cn/6lPx9vD XYRztXY4RbowhhmJ3ONncfiU2mFh9FmbJ+8a38X3SQ064ZLDr2V5fpKh3gQwBLwoATPbPx6h jpYx+Ep7StQhugZuQ9rxy+UBr0UHk5GFSPpnhWMqdu5qe8EAQTnOaj1z0d4kd27WfuHqxFdX TDwcJ4mEClz6dtXP1fF0Xm14YbhMoq1D5pbpliflBHOiPJQIZQ6m68RhCZpDmn6uGUs1+8xi RE9lYH/poWMLH9hub6oGhMNfCOgfNsdo3u+6MQW1tbTxY2kGY9tXykGTIe9B+z9Cyoc7LzmL 1rcS2B68ybDX+CDQknHrx0653PXT8L1azfNfyJflIs6AkHafR064khcXS1mzMBnUFnynoq5N h8+vGhZ50ak+EUSjLg0Zl+vCiGH413wIjYsFMrAdlwPskcbth2TaYvHvocRV2lZ5sHz81DLc zbGIVwOVSZQBASFHwyxZ+H+o4CfrK7IQLL5daKGYK3S+7UBDLHRlM7pis0+uG/SU6fHdnh6U 69hghsFDS0/Qp6J3W1IEnNfljqRPZTC+lHhqmsu/5r5qLOyCUru/dfdUeIMd480qlbt2+Hbc LfB4UQxYSBR0pdGrZPR4J4Y2lNayyRndj33VK8FqTaIVqXb3KleEx8cbSp3cspO9aM1mAdXa 4bdjZvu27h0g+RQaR8NXEH9msyvec0BIn2sfFLBCkGRMb2aJDrNi8jpaKK4QLdUga1arRq18 TqcFkbiOHyEmVyLH1i3NvpQiSiAIBFEkIS0cxIoFnK6Cdy6MVu0N9h4iTBwyroxxzvLOWMaL TlgYhZNo7mXvkY6yr10H21M6GYgLPHRwX7IqbmFbMxM6L03WXcR9aoS+nkxxrpL4TsRQfV0n HGXtdtyuxS8leLJzDN7UR1IozINhYSRvEwkN7+Kk/sIEXvC4h8J6n2dThoQoN4wQNjmq6FVj NHFnab+LjRF7frb+MIdA47fL8fNYx9DeVL5XSXZCgcIV2vhLWbEm0lUi+2f7FWQp5k+74f2w d8AFuQdW1syGfcXTE9iGZZRRfU/FiNhmrmdgskS4HO4pxSEX8RWsKfMUfeKCOnuIjKU5VGrT xQNyLL8a48UM9+is6SHQlZ/lYXOXUHXWIIVysWARgo9oUEI72InC2NvgATqbQSi5HJVHvmxz EZetw==
  • Ironport-sdr: 67069868_RNS7e4AtgcBd1VMGag3b0XV33MoZDnHVOuKNhpPbFUJqFDw 8rCRF6VmZ/jDe9ffwVluoKvD6Y2aBLHRY7d+8NQ==
Dear all,
How are you? I hope all is well with you. I need help please. I’m parallelising a stencil-based C code for shared-memory using StarPU. The general algorithm consists of five computation phases launched in a loop over time:
initialise StarPU
create data handles for arrays
register data with StarPU
create vector block filter
apply filter to partition data
for (int t = 0; t < tmax; t++) {
calc_phase1_starpu;
calc_phase2_starpu;
calc_phase3;
calc_phase4;
calc_phase5;
unpartition data
unregister data arrays
finalise StarPU
My questions are
1) First two phases I already converted to StarPU. Can you please check I’m using StarPU in a performant manner, i.e. can you confirm that it is better to register and partition the data before the main time loop iterations and un-partition it at the end? So far I see very strong performance degradation of my code. It is worse than the sequential version of the code. Maybe it is not recommended to mix StarPU code with non-StarPU sequential code?
2) My code crashes with the following error message at the very end of execution:
[starpu][_starpu_task_submit][assert failure] starpu_init must be called (and return no error) before submitting tasks.
Assertion failed: (0 && "starpu_is_initialized()"), function _starpu_task_submit, file task.c, line 956.
Would you please guide me on how to debug this error? I’m sure I called ‘starpu_init’ before I submitted my tasks. I suspect this error is issued by the ‘starpu_shutdown’ routine at the very end of my program. Thank you and have a great afternoon ahead!
Best wishes,
Maxim
Maxim Abalenkov \\ maxim.abalenkov@gmail.com
+44 7 486 486 505 \\ www.maxim.abalenkov.uk
Haut de le page
