Archives de la liste
Re: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error]
Chronologique Discussions
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error]
- Date: Fri, 11 Oct 2024 14:43:09 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Hello,
Maxim Abalenkov, le ven. 11 oct. 2024 12:16:54 +0100, a ecrit:
> Can you please dedicate five minutes to read and respond to my email?
Now that the IPDPS deadline is over, yes.
> 1) First two phases I already converted to StarPU. Can you please check
> I’m
> using StarPU in a performant manner, i.e. can you confirm that it is
> better
> to register and partition the data before the main time loop iterations
> and
> un-partition it at the end?
Yes.
> So far I see very strong performance degradation of my code. It
> is worse than the sequential version of the code. Maybe it is not
> recommended to mix StarPU code with non-StarPU sequential code?
No, that should not really be a problem. But how large your tasks
are? See the checklist item about task sizes:
https://files.inria.fr/starpu/doc/html/CheckListWhenPerformanceAreNotThere.html#CheckTaskSize
That being said, you will probably want to put starpu_pause() /
starpu_resume() around your not-yet-starpufied code, otherwise StarPU
monopolizes all CPU cores, which can thus degrade the performance of the
non-starpufied code.
> 2) My code crashes with the following error message at the very end of
> execution:
> [starpu][_starpu_task_submit][assert failure] starpu_init must be
> called (and return no error) before submitting tasks.
> Assertion failed: (0 && "starpu_is_initialized()"), function
> _starpu_task_submit, file task.c, line 956.
Please also post a backtrace, to make sure of the context of the call.
> Would you please guide me on how to debug this error? I’m sure I called
> ‘starpu_init’ before I submitted my tasks. I suspect this error is
> issued
> by the ‘starpu_shutdown’ routine at the very end of my program.
The error looks like you have called starpu_shutdown within your
program, before the last task submission.
Posting your actual code would help to check what is going wrong.
Samuel
- [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error], Maxim Abalenkov, 09/10/2024
- Re: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error], Maxim Abalenkov, 11/10/2024
- Re: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error], Samuel Thibault, 11/10/2024
- Re: [starpu-devel] [StarPU for stencil-based code: logic, starpu_shutdown error], Philippe SWARTVAGHER, 11/10/2024
