Archives de la liste
- To: Xinbo Li <lix34545@myumanitoba.ca>
- Subject: Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling
- Date: Fri, 18 Apr 2025 02:47:43 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Neutral smtp.mailfrom=samuel.thibault@aquilenet.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
- Resent-date: Fri, 18 Apr 2025 03:06:01 +0200
- Resent-from: Samuel Thibault <samuel.thibault@aquilenet.fr>
- Resent-message-id: <aAGleb93qXUKbSkY@begin>
- Resent-to: starpu-devel@inria.fr
Xinbo Li, le ven. 18 avril 2025 00:44:39 +0000, a ecrit:
> In that case, if we define a data handle inside a local block and
> unregister it
> immediately after task submission, any subsequent tasks — even if unrelated
> would be forced to wait for the earlier tasks to complete, due to the
> synchronization imposed by the unregister operation. This could potentially
> reduce efficiency.
Yes. That's why you'd prefer to just let starpu handle allocation by
passing a NULL pointer (and possibly use a task to initialize data in
it), and use starpu_data_unregister_submit after inserting all tasks
using it.
> // Task 1
> starpu_task_insert(
> &some_codelet,
> STARPU_RW, handle,
> 0);
> starpu_data_unregister(handle); // unregister at end of block
> // Task 2
> starpu_task_insert(
> &some_other_codelet,
> STARPU_RW, some_other_handle,
> 0);
> In this case, would Task 2 be forced to wait for Task 1 to finish,
starpu_data_unregister waits for the completion of task 1, yes.
Samuel
- [starpu-devel] StarPU Question: Using Local Variable as Data Handles?, Xinbo Li, 17/04/2025
- Re: [starpu-devel] StarPU Question: Using Local Variable as Data Handles?, Samuel Thibault, 17/04/2025
- [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Xinbo Li, 18/04/2025
- Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Samuel Thibault, 18/04/2025
- Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Xinbo Li, 18/04/2025
