Archives de la liste
- To: Xinbo Li <lix34545@myumanitoba.ca>
- Subject: Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling
- Date: Fri, 18 Apr 2025 03:05:37 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Neutral smtp.mailfrom=samuel.thibault@aquilenet.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
- Resent-date: Fri, 18 Apr 2025 03:06:01 +0200
- Resent-from: Samuel Thibault <samuel.thibault@aquilenet.fr>
- Resent-message-id: <aAGleR7Mtsl-vgTR@begin>
- Resent-to: starpu-devel@inria.fr
Xinbo Li, le ven. 18 avril 2025 01:03:56 +0000, a ecrit:
> It is more recommended to do:
> // Method 2. StarPU handles the memory allocation for data
> starpu_data_handle_t handle;
> starpu_custom_data_register(&handle, -1, nullptr);
> starpu_task_insert(&codelet_that_prepares_data, STARPU_RW, handle, 0);
Yes, but rather STARPU_W: there's no initial value here.
Samuel
- [starpu-devel] StarPU Question: Using Local Variable as Data Handles?, Xinbo Li, 17/04/2025
- Re: [starpu-devel] StarPU Question: Using Local Variable as Data Handles?, Samuel Thibault, 17/04/2025
- [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Xinbo Li, 18/04/2025
- Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Samuel Thibault, 18/04/2025
- Re: [starpu-devel] Follow-Up on Data Handle Scope and Task Scheduling, Xinbo Li, 18/04/2025
