Archives de la liste
- From: Andrew Mary-Huet-De-Barochez <andrew.mary-huet-de-barochez@univ-smb.fr>
- To: starpu-devel <starpu-devel@inria.fr>
- Subject: [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build
- Date: Mon, 16 Jun 2025 17:04:48 +0200 (CEST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=andrew.mary-huet-de-barochez@univ-smb.fr; spf=Pass smtp.mailfrom=andrew.mary-huet-de-barochez@univ-smb.fr; spf=None smtp.helo=postmaster@smtpout01-ext2.partage.renater.fr
- Dkim-filter: OpenDKIM Filter v2.10.3 zmtaout05.partage.renater.fr 2EBDFA0115
- Ironport-sdr: 68503292_2O1b8Cn6bJxIsj00NCdmCYMcB6zhNgCu1+8gX3uORTK300C kVyf5dvyhAnDV4YkeCoIg9nFqWcuq2U+j5GTIQQ==
Hello,
I noticed the macros STARPU_MATRIX_SET_NX/NY/LD rely on the other macro STARPU_MATRIX_CHECK, but this last is only defined when compiling in release mode.
I guess they should be defined two times for debug/release like STARPU_MATRIX_GET_PTR and others.
Same goes for STARPU_VECTOR_SET_NX.
Also would it be possible to have a gitlab account please?
This way I could submit pull request / issues, it may be easier for you :)
I use StarPU among my thesis work.
Thanks a lot!
Andrew Mary Huet de Barochez.
- [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build, Andrew Mary-Huet-De-Barochez, 16/06/2025
- Re: [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build, Samuel Thibault, 19/06/2025
