Archives de la liste
- To: Andrew Mary-Huet-De-Barochez <andrew.mary-huet-de-barochez@univ-smb.fr>
- Cc: starpu-devel <starpu-devel@inria.fr>
- Subject: Re: [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build
- Date: Thu, 19 Jun 2025 14:18:53 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Hello,
Andrew Mary-Huet-De-Barochez, le lun. 16 juin 2025 17:04:48 +0200, a ecrit:
> I noticed the macros STARPU_MATRIX_SET_NX/NY/LD rely on the other macro
> STARPU_MATRIX_CHECK, but this last is only defined when compiling in release
> mode.
> I guess they should be defined two times for debug/release like
> STARPU_MATRIX_GET_PTR and others.
Ah, indeed!
> Also would it be possible to have a gitlab account please?
> This way I could submit pull request / issues, it may be easier for you :)
Indeed, I have create an account with your
andrew.mary-huet-de-barochez@univ-smb.fr email address. Feel free to
submit a PR for the issue above :)
Samuel
- [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build, Andrew Mary-Huet-De-Barochez, 16/06/2025
- Re: [starpu-devel] STARPU_MATRIX_SET_NX/NY/LD release build, Samuel Thibault, 19/06/2025
