Archives de la liste
- To: typographie AT irisa.fr
- Subject: Caracteres phonetiques du suisse allemand
- Date: Thu, 22 May 2003 21:58:46 +0000
Ayant reçu ceci dans un des forums auxquels je participe, je le retransmets, parce qu'il peut intéresser certains d'entre-vous.
Jacques Melot
X-Sender:
evr001 AT mail.dna.ie
Date: Thu, 22 May 2003 11:17:22 +0200
Reply-To: "Older Germanic languages (to 1500),
their linguistics and philology"
<GERLINGL AT LISTSERV.UIUC.EDU>
Sender: "Older Germanic languages (to 1500),
<everson AT EVERTYPE.COM>
Subject: Re: Swiss Phonetic Alphabet
To:
X-MailScanner: Found to be clean
Anyone know about this?
"Switzerland has his own phonetic alphabet (it is used for the old
german that is very near the swiss language Swiss German). At the
moment each project uses a special font and different tricks in
order to publish their book. The problem is not that much new
characters but the combinations with dead character like diaeresis
that change the way you should pronounce this character. The
difficulty is that we often need several modifiers (two over the
character and one or two under). That means that we first need to be
able to have up to 4 modifiers and that the character still has to
be nicely represented otherwise you cannot see which modifiers are
in use...."
The idea is to determine if there are characters missing from Unicode.
Michael Everson * * Everson Typography * * http://www.evertype.com
- Caracteres phonetiques du suisse allemand, Jacques Melot, 22/05/2003
