Accéder au contenu.
Menu Sympa
typographie - RE: [typo] Quelques questions de débutant
Archives de la liste
Chronologique Discussions
  • To: typographie AT listes.irisa.fr
  • Subject: RE: [typo] Quelques questions de débutant
  • Date: Wed, 9 Jan 2019 21:13:41 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=philpask AT gmail.com; spf=Pass smtp.mailfrom=philpask AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f54.google.com
  • Ironport-phdr: 9a23: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
C’est tout à fait ça. Les petites cibles s’appellent des hirondelles dans le jargon imprimeur ;-) Mais cela ne sert plus à rien en numérique, même en offset. Les logiciels qui font la transcription pour l’impression les mettent automatiquement. Du moment que le pdf est aux normes de l’impression, pas de souci particulier. Et si le document ne contient pas de matière qui par à la coupe, vous pouvez même le livrer au format fini (A4 par exemple ou 21 x 27 cm).
Les polices, c’est à votre convenance et vos envies.
Philippe
Le 9 janv. 2019 à 19:49 +0100, thuwart AT proximus.be, a écrit :
Merci beaucoup. J’en déduis que, pour peu que mon texte quel qu’il soit (en russe, grec, babylonien…)
soit livré sous forme de fichier PDF conforme et en respectant le gabarit donné (je suppose des « petites cibles »
aux quatre coins et un étalon couleur, tout cela pour des rogneuses automatiques), n’importe quel éditeur s’en
sort et n’a pas besoin de savoir comment j’ai créé mon PDF.
C’est ma traduction de votre intervention et avec ceci, j’ai globalement assez.
Quant aux polices (j’aime bien Adobe Garamond pour le texte et Minion Pro pour les maths), on les change en deux
lignes de code. Ça prend 2 ou 3 minutes pour générer un nouveau PDF.
Bonne soirée.
De : typographie-request AT listes.irisa.fr [mailto:typographie-request AT listes.irisa.fr] De la part de jtombeur AT cegetel.net
Envoyé : mercredi 9 janvier 2019 18:59
À : typographie AT listes.irisa.fr
Objet : Re: [typo] Quelques questions de débutant
Bon, les maths et moi, cela fait deux, voire n.
Thierry Bouche pourrait peut-être vous répondre savamment (ainsi que quelques autres...).
Mais à mon humble avis, vos préoccupations frisent, dans la plupart des cas (soit des éditeurs, imprimeurs, &c.), le superflu...
Si vous trouvez un éditeur, demandez-lui un gabarit, et fournissez-lui un PDF conforme (de nos jours, la plupart sont conformes).
Et roulez machines (offset ou autres). Sauf que... À mon époque, l'offset présumait un fichier CMJB (ou CMYB en ang. si je me souviens bien). Cela étant, pour des graphiques (contrairement aux photos en quadrichromies), l'importance est bien moindre. Vos RVB devraient faire l'affaire.
Très bonne année aussi.
De : thuwart AT proximus.be
A : typographie AT listes.irisa.fr
Envoyé: mercredi 9 janvier 2019 18:43
Objet : [typo] Quelques questions de débutant
Bonsoir à toutes et tous et bonne année 2019.
Je ne suis pas professionnel de l’imprimerie mais, pour mon plaisir, j’ai commencé à rédiger un livre de mathématiques.
Ce loisir me permet de revoir bien des détails et des formules oubliés mais aussi de parfois programmer un peu (j’adore ça)
et de préférence proprement. J’ai parfois l’impression de me balader comme un éléphant dans un magasin de porcelaine, aussi J
Je ne sais pas si je franchirai un jour le pas de faire éditer (par un éditeur) mon ouvrage. Mais avant d’aller trop loin dans la
rédaction, et éviter d’avoir à recommencer à cause de choix inappropriés, j’aimerais quelques conseils pratiques.
A terme, mon objectif est de présenter un ouvrage « correct » demandant peu de lourdes modifications pour passer à l’impression.
J’écris le texte en lualatex, plus convivial pour jongler avec les fontes (en maths, on a parfois des surprises). Chez les éditeurs,
LaTeX et lualatex sont-ils maîtrisés pour des corrections de remise en forme, sans y passer des semaines ? Bref, est-ce un
outil standard, ou totalement atypique ?
Pour les graphiques, j’ai choisi TikZ pour son aspect dense et la puissance de calcul dans les dessins complexes.
Même question : est-ce répandu chez les éditeurs ?
Pour l’ouvrage proprement dit, j’ai pris le pari d’une présentation bicolore : textes et titres en noir, figures en monochrome (vert,
bleu ou orangé : il suffit de configurer un code RGB en début de document et de recompiler). Comme la couleur est unique,
cela évite les couleurs flash (j’aime pas ça) et de définir une sorte de « code couleur » complexe et constant à travers l’ouvrage.
Mais désigner plusieurs caractéristiques d’une même figure est plus délicat : je jongle avec les
pointillés, les traits discontinus, l’épaisseur des traits et la transparence du fond (dont la couleur peut devenir plus soutenue
quand elle se situe à l’intersection de plusieurs formes) – voir figure jointe.
Pour un éditeur, une édition N&B+une couleur coûte-elle cher ? Et si on choisit une couleur, passe-t-on sans gros surcoût à la quadrichromie ?
Jouer sur la transparence pose-t-il problème (qualité du papier, de l’encre) au point de devoir réajuster le code ?
Pour ce type d’ouvrage, quelle est la taille recommandée (en points) des caractères du corps de texte, habituellement ?
Merci d’avance de vos avis et conseils éclairés.
La liste Typo — discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe typographie>
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
JPEG image
Archives gérées par MHonArc 2.6.18.
Haut de le page
