Archives de la liste
- From: "Jacques ANDRÉ" <jacques.andre35 AT gmail.com>
- To: typographie AT listes.irisa.fr
- Subject: [typo] Mauvais usage d'abréviations « mathématiques »
- Date: Thu, 7 May 2020 13:44:12 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jacques.andre35 AT gmail.com; spf=Pass smtp.mailfrom=jacques.andre35 AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f42.google.com
- Ironport-phdr: 9a23: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
Bonjour,
Une constatation ancienne que cette période de confinement remet en évidence
(peut-être seulement parce que je prend le temps de regarder ?) :
beaucoup de gens ont tendance à utiliser des abréviations ou signes
abréviatifs dans les écrits privés mais aussi, merci les ordi et imprimantes
« perso », dans des affichettes, annonces diverses ; et aussi sur le web.
Le problème est la grande confusion due sans doute à une méconnaissance des
maths (du niveau de 4e ?), voire du français, et sans doute un détournement
des signes présents sur nos claviers d'ordi.
Voici deux exemples vus ce matin :
- Sur la porte du tabac à côté de chez moi : « La vente des cigarettes est
interdite aux mineurs de -18 ans » pour « ... moins de 18 ans ».
Confusion entre « moins » (signe marquant la négation) et « moins de »
(opérateur de relation), « - » et « < ».
- Je viens de faire une commande de légumes : prix des poireaux : « 4 €, +/-
1 kg », heure de livraison : « +/- 14 h ».
D'abord =/- devrait être remplacé par ± qui en fait veut dire « plus ou
moins » et il faudrait écrire « 4 € le kg ± 50 g » et « 14 h ± 10 min » (et
là je ne pinaille pas sur les abréviations pour kilogramme, heure et minute).
Mais en fait, ce que l'on veut écrire c'est « 4 € pour 1 kg environ » et «
vers 14 h ». Ce qui pourrait alors s'abréger, si on y tient, par « ~1 kg » et
« : ~ 14 h ».
Outre ces confusions de sens, j'ai aussi envie d'expliquer ceci par le fait
que sur les claviers de certains ordinateurs et sur beaucoup des smartphones,
les signes « < > ± » (guillemets compris !) ne sont pas d'accès immédiat
(mais en général bien présents...).
Ça m'agace... mais ne sait que faire !
Connaissez-vous d'autres exemples ?
Jacques André
- [typo] Mauvais usage d'abréviations « mathématiques », Jacques ANDRÉ, 07/05/2020
- Re: [typo] Mauvais usage d'abréviations « mathématiques », Jacques Melot, 09/05/2020
- <Suite(s) possible(s)>
- Re: [typo] Mauvais usage d'abréviations « mathématiques », jtombeur, 07/05/2020
- Re: [typo] Mauvais usage d'abréviations « mathématiques », Jacques Dyoniziak, 07/05/2020
Archives gérées par MHonArc 2.6.18.
