Accéder au contenu.
Menu Sympa
typographie - Re: [typo] Usage des accents
Archives de la liste
Chronologique Discussions
  • To: typographie AT inria.fr
  • Subject: Re: [typo] Usage des accents
  • Date: Wed, 11 Aug 2021 09:12:16 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pachot2 AT gmail.com; spf=Pass smtp.mailfrom=pachot2 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qv1-f54.google.com
  • Ironport-hdrordr: A9a23:139x8K0DayeWhgoGLRB9kgqjBJEkLtp133Aq2lEZdPUnSL3lqynIpoVn6faUskdqZJhEo7q90ca7MBXhHPJOkO0s1PKZLXLbUQiTXflfBOnZslrd8kTFn4Y3tZuIMZIObeEYZWIasS+Q2njaLz9P+qjkzEnlv5am856vd21XgmNbgjuRxjz1LqS+fmd7OaY=
  • Ironport-phdr: A9a23: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
Le 2021-07-27 à 10:00, Jacques Melot a écrit :
En français, l'usage est de ne pas accentuer les majuscules
Argh, j’ai failli m’étouffer.
D’où sort-il cet usage ? Certainement pas du Bon Usage !
Du temps des machines à écrire, cette règle avait du sens. Depuis l’usage de l’ordinateur, ce n’est plus le cas.
Sur le clavier canadien (et belge aussi visiblement) cela se fait très facilement : il suffit tout simplement d’appuyer sur la touche majuscule + la lettre minuscule accentuée !
N’oublions pas que depuis 2003 il existe le clavier Bépo qui permet d’accentuer facilement les majuscules, sans compter les espaces fines.
Et que depuis 2019, il y a une norme AFNOR pour les claviers français qui présente deux claviers (dont le Bépo). Le problème avec le clavier français était notamment l’accentuation des majuscules. Bizarre, je croyais que l’usage était le ne pas les accentuer.
https://normalisation.afnor.org/actualites/faq-clavier-francais/
En tout cas, si c’est une règle que vous avez apprise à l’école lorsque vous étiez petit, il faut peut-être la remettre en cause !
Je serais curieux de savoir comment votre « usage » interprète le titre suivant : UN INTERNE TUE
https://www.antidote.info/fr/blogue/enquetes/faut-il-accentuer-les-majuscules-et-les-capitales
Et puis il faudrait aussi demander à Jacques André de réécrire ses Petites leçons de typographies (1990). Page 4, on a « les majuscules doivent être accentuées »
https://jacques-andre.fr/faqtypo/lessons.pdf
Il y a de très fortes chances que depuis 1990 l’usage est évolué !
Haut de le page
