Archives de la liste
- To: typographie AT inria.fr
- Subject: Re: [typo] Usage des accents
- Date: Thu, 12 Aug 2021 08:45:16 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=salix9506 AT gmail.com; spf=Pass smtp.mailfrom=salix9506 AT gmail.com; spf=None smtp.helo=postmaster AT mail-il1-f174.google.com
- Ironport-hdrordr: A9a23:JE1mCq+LKR3d7T0ObDpuk+C2I+orL9Y04lQ7vn2ZLiY6TiX4rayTdZsgvyMc5AxxZJhQo7290cC7KBvhHPVOirX5U43MYDXb
- Ironport-phdr: A9a23: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
Bonjour,
J'approuve tout à fait.
La preuve en est faite, de l'utilité des accents sur nos mâles Juscules.
Mais, quand même, "que l’usage ait évolué !".
Au revoir.
Le mer. 11 août 2021 à 15:14, Alexandre Pachot <pachot2 AT gmail.com> a écrit :
Le 2021-07-27 à 10:00, Jacques Melot a écrit :
> En français, l'usage est de ne pas accentuer les majuscules
Argh, j’ai failli m’étouffer.
D’où sort-il cet usage ? Certainement pas du Bon Usage !
Du temps des machines à écrire, cette règle avait du sens. Depuis
l’usage de l’ordinateur, ce n’est plus le cas.
Sur le clavier canadien (et belge aussi visiblement) cela se fait très
facilement : il suffit tout simplement d’appuyer sur la touche majuscule
+ la lettre minuscule accentuée !
N’oublions pas que depuis 2003 il existe le clavier Bépo qui permet
d’accentuer facilement les majuscules, sans compter les espaces fines.
Et que depuis 2019, il y a une norme AFNOR pour les claviers français
qui présente deux claviers (dont le Bépo). Le problème avec le clavier
français était notamment l’accentuation des majuscules. Bizarre, je
croyais que l’usage était le ne pas les accentuer.
https://normalisation.afnor.org/actualites/faq-clavier-francais/
En tout cas, si c’est une règle que vous avez apprise à l’école lorsque
vous étiez petit, il faut peut-être la remettre en cause !
Je serais curieux de savoir comment votre « usage » interprète le titre
suivant : UN INTERNE TUE
https://www.antidote.info/fr/blogue/enquetes/faut-il-accentuer-les-majuscules-et-les-capitales
Et puis il faudrait aussi demander à Jacques André de réécrire ses
Petites leçons de typographies (1990). Page 4, on a « les majuscules
doivent être accentuées »
https://jacques-andre.fr/faqtypo/lessons.pdf
Il y a de très fortes chances que depuis 1990 l’usage est évolué !
La liste Typo — discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
NUALTRIS FURLANS CANIPLAS IL VIN BON
- Re: [typo] Usage des accents, Thierry Bouche, 03/08/2021
- <Suite(s) possible(s)>
- Re: [typo] Usage des accents, Alexandre Pachot, 11/08/2021
- Re: [typo] Usage des accents, Jacques Poitou, 11/08/2021
- Re: [typo] Usage des accents, salix9506, 12/08/2021
