cado-nfs - [Cado-nfs-discuss] problem in sieve stage
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] problem in sieve stage
  • Date: Mon, 8 Jul 2013 15:45:22 +0800 (CST)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi all,
   I try to factor rsa155  as directed by cadofactor.pl. In sieving stage, I find some warning "~/c155 rsa155.rels.xxx-yyy.gz contains no useable data, deleting". And in directory /tmp, I find the file rsa155.rels.xxx-yyy.gz often changes, with size  from zero to a higher value and then to zero again. That is, the file was overwritten or the job was redone many times. Now the factoring has taken very long time, but I only get 10 gz file in work directory ~/c155.
  Is this normal? or what's wrong?
 Thank you.
 Regards,
sincerely Meng
