- To: Emmanuel Thomé <emmanuel.thome@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] problem in sieve stage
- Date: Mon, 22 Jul 2013 11:30:52 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
> - system and/or compiler bug. Miscompilations do happen. I don't
> recall whether gcc-4.1.2 was on the blacklist or not, but I do recall
> that some oldish libcs had a problem with threads which impacted
> cado-nfs. You can try to compile with a more recent gcc, for instance.
> You may also try to run the above command without the "-mt 4"
> parameter.
yes gcc-4.1.2 is on the blacklist. From README:
* GCC 4.1.2 is known to miscompile CADO-NFS (see
https://gforge.inria.fr/tracker/index.php?func=detail&aid=14490),
GCC 4.2.0, 4.2.1 and 4.2.2 are also affected
Paul Zimmermann
- [Cado-nfs-discuss] problem in sieve stage, meng, 07/08/2013
- Re: [Cado-nfs-discuss] problem in sieve stage, Alexander Kruppa, 07/08/2013
- <Possible follow-up(s)>
- Re: [Cado-nfs-discuss] problem in sieve stage, meng, 07/19/2013
- Re: [Cado-nfs-discuss] problem in sieve stage, Emmanuel Thomé, 07/19/2013
- Re: [Cado-nfs-discuss] problem in sieve stage, Zimmermann Paul, 07/22/2013
