cado-nfs - Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment
  • To: meng <qsmeng@126.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment
  • Date: Fri, 26 Jul 2013 09:18:18 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> yes, I remake the version 8efeb35. With c59, the repeat las problem exists.
> With c90, it has no repeat problem or it work well. With rsa100, the
> By the way, commit version f78e49c doesnot have repeat las problem.
version f78e49c is quite old, trying it is not very useful.
Please can you send us the rsa100.poly file you used, and the las command that
fails, so that we can try to reproduce the problem?
Thanks in advance,
Paul Zimmermann
