- To: Shi Bai <shih.bai@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr, qsmeng@126.com
- Subject: Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment
- Date: Tue, 30 Jul 2013 08:29:22 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
> Date: Tue, 30 Jul 2013 09:53:23 +1000
> From: Shi Bai <shih.bai@gmail.com>
> Dear Meng,
> > I noticed that in the output of gdb, there exists one strange sentence
> > "# Compiled with gcc 4.1.2 20080704 (Red Hat 4.1.2-52)"
> > My gcc now is gcc-4.4.6. Maybe cmake is compiled by gcc4.1.2? Or something
> > in make is set to old gcc? Anyway I will remake the cmake and check the
> > result.
> It seems that the las is still compiled by gcc 4.1.2. Have you set the
> options
> CC=
> and
> CXX=
> to gcc-4.4 (and g++-4.4) in the file "local.sh"?
> Best,
> Shi
yes this is most probably the reason of the failure you get.
Paul Zimmermann
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, (continued)
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/26/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/26/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/28/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/29/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/29/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/30/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Shi Bai, 07/30/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/30/2013
