- To: "Shi Bai" <shih.bai@gmail.com>, "Zimmermann Paul" <paul.zimmermann@inria.fr>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment
- Date: Tue, 30 Jul 2013 17:50:14 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Shi and Paul,
Indeed after I set CC=/home/greatnet/gcc-4.4.6/gcc and CXX=/home/greatnet/gcc-4.4.5/g++, and then make, the las repeat problem disappear. Thank you both and other people who once helped to resolve this problem.
My os is redhat with gcc=4.1.2. At first, I did not know gcc -4.1.2 can cause problem. Later I think of the reason when reading the README and update gcc to 4.4.6. I export the PATH and LI_LIBRARY_PATH in .bashrc, and gcc -v return version 4.4.6 in any directory. I don't know why I should set them in local.sh. Or what configuration let the cado-nfs to use gcc4.1.2?
Anyway, I am sorry for this. It takes you so much time.
Thank you again.
Best regards,
Meng
Thank you again.
Best regards,
Meng
At 2013-07-30 07:53:23,"Shi Bai" <shih.bai@gmail.com> wrote: >Dear Meng, > >> I noticed that in the output of gdb, there exists one strange sentence >> "# Compiled with gcc 4.1.2 20080704 (Red Hat 4.1.2-52)" >> My gcc now is gcc-4.4.6. Maybe cmake is compiled by gcc4.1.2? Or something >> in make is set to old gcc? Anyway I will remake the cmake and check the >> result. >It seems that the las is still compiled by gcc 4.1.2. Have you set the options > >CC= >and >CXX= > >to gcc-4.4 (and g++-4.4) in the file "local.sh"? > >Best, >Shi > > >> Thank you very much. >> Best regards, >> Meng >> >> >> >> >> _______________________________________________ >> Cado-nfs-discuss mailing list >> Cado-nfs-discuss@lists.gforge.inria.fr >> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss >>
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, (continued)
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/26/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/26/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/28/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/29/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/29/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, meng, 07/30/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Shi Bai, 07/30/2013
- Re: [Cado-nfs-discuss] Fw:Re:Re: makefb not found in distributed enviroment, Zimmermann Paul, 07/30/2013
