cado-nfs - [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • To: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • Date: Tue, 8 Oct 2013 14:48:38 +0200 (CEST)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear users,
we are working towards the release of version 2.0 of CADO-NFS. There is much
new functionality and new code; the enterprising among you are cordially
invited to try out the current alpha release, to report any bugs that you may
encounter and to pose any questons that may arise.
The source tarball
cado-nfs-2.0alpha_a23402ef.tar.gz
can be found at
https://gforge.inria.fr/frs/?group_id=2065
>From the release notes:
Main changes between cado-nfs-1.1 and cado-nfs-2.0:
* the default parameters in the params subdirectory have been improved
* major speedups in the polynomial selection, sieving and filtering steps
* the filtering step produces a smaller matrix (about 5% less rows),
see http://hal.inria.fr/hal-00734654 for more details.
* the replay step is faster and uses less memory
* fixed bug in the lattice siever (las) on 32-bit computers
* allow compilation on MinGW32. Performance is poor, however. MinGW64 is
currently not supported
* new cadofactory script written in Python, allows larger-scale distribution
with client/server model
* implementations of NFS-DL and NFS-FFS (experimental, requires some
background knowledge to use)
WARNING: the cadofactor.py script starts an HTTP server through which it
distributes work to client scripts; this server currently performs no
authentication. This is to be fixed. For the time being, you are advised not
to run the server on an address visible to machines which you don't control.
Letting the server listen only on "localhost" on a private machine is a safe
bet; alternatively the most restrictive firewall rules should be used.
Thanks and happy factoring,
The CADO team
