cado-nfs - Re: [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • To: Alexander Kruppa <alexander.kruppa@inria.fr>
  • Cc: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • Date: Fri, 11 Oct 2013 15:01:24 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Fri, 2013-10-11 at 14:10 +0200, Alexander Kruppa wrote:
> It probably should check the version of Python at least. I'm a bit
> surprised by this error; the sqlite3 module was added to the Python
> standard library in 2.5, and cadofactor.py requires Python 3 to run at all.
> Which versions of Python are installed? I.e., which (if any) do you get by
> executing "python -V", "python2 -V", and "python3 -V"?
With Alex' assistance this is now working and a c93 has duly been
factored.
The requirement is that under Gentoo the Python packages must have the
"sqlite" USE flag set and a note to this effect in the docs would be a
good idea. If wished, I could start a system-dependency gotcha README
file.
Paul
