cado-nfs - Re: [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • To: Alexander Kruppa <alexander.kruppa@inria.fr>
  • Cc: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Alpha release of CADO-NFS 2.0 available for testing
  • Date: Fri, 11 Oct 2013 13:19:29 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Fri, 2013-10-11 at 14:10 +0200, Alexander Kruppa wrote:
> It probably should check the version of Python at least. I'm a bit
> surprised by this error; the sqlite3 module was added to the Python
> standard library in 2.5, and cadofactor.py requires Python 3 to run at
> all. Which versions of Python are installed? I.e., which (if any) do
> you get by executing "python -V", "python2 -V", and "python3 -V"?
I made the mistake of mailing the information below from my main email
account, which Inria doesn't like and which has just been bounced. It
addresses your response.
Further to this, there's a more serious problem. The Python sqlite3
module is "Masked", or not installable without risky hackery, on 64-bit
Gentoo. Not sure what to recommend, though I could arrange for
appropriate dev access to this system if needed for debugging.
pcl@maat ~/cado-nfs-2.0alpha_a23402ef $ emerge -s sqlite3
Searching...
[ Results for search key : sqlite3 ]
[ Applications found : 5 ]
* dev-python/sqlite3dbm [ Masked ]
Latest version available: 0.1.4-r1
Latest version installed: [ Not Installed ]
Size of files: 18 kB
Homepage: https://github.com/Yelp/sqlite3dbm
http://pypi.python.org/pypi/sqlite3dbm/
Description: An sqlite-backed dictionary
License: Apache-2.0
pcl@maat ~/cado-nfs-2.0alpha_a23402ef $ python -V
Python 2.7.3
pcl@maat ~/cado-nfs-2.0alpha_a23402ef $ python2 -V
Python 2.7.3
pcl@maat ~/cado-nfs-2.0alpha_a23402ef $ python3 -V
Python 3.2.3
Paul
