- To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] sieving takes too much time
- Date: Sun, 14 Dec 2014 13:02:34 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi all,
Using the two nonlinear polynomial given by Williams, I tried to factor C59 by running "./cadofactor.py params.c59" under the direction of Readme.nonlinear. Everything seems to be ok, but the sieving stage took too much time(several hours) . The screen displays the following and no progress:
Info:Lattice Sieving: Adding workunit c59_sieving_91845-93845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_93845-95845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_95845-97845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_97845-99845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_99845-101845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_101845-103845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_103845-105845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_105845-107845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_107845-109845 to database
Info:Lattice Sieving: Adding workunit c59_sieving_109845-111845 to database
Obviously it is not normal. Would you please help to fix this problem? Thank you in advance.
Best regards,
Qingshu Meng
- [Cado-nfs-discuss] sieving takes too much time, meng, 12/14/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/16/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, Shi Bai, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, paul zimmermann, 12/17/2014
- Re: [Cado-nfs-discuss] sieving takes too much time, meng, 12/18/2014
