- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Fine tuned task/stage control
- Date: Thu, 17 Mar 2016 03:49:29 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bunslow@gmail.com; spf=Pass smtp.mailfrom=bunslow@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f53.google.com
- Ironport-phdr: 9a23:7WCBvxMX8Sm9FjkGk8Ql6mtUPXoX/o7sNwtQ0KIMzox0KPn9rarrMEGX3/hxlliBBdydsKIUzbKN+Pm6ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTnkbjpsMSJO01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdK00SvleAi9jP2Eu79DwrjHHTBCT/T0TXGIMnRcOAg7f7Ri8UI2inDH9s79X2S2edfL3S6swXivqu612TgTsjzgvODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/vQ
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello everyone.
I am Dubslow from http://mersenneforum.org, and I've just downloaded CADO for the first time to try out its polyselect capabilities on a C195 from aliquot sequence 4788. The general consensus around MersenneForum is that all stages of CADO-NFS are marginally inferior to msieve/ggnfs, with the notable exception of the GNFS polynomial selection.
For most large GNFS tasks these days, the folks over at MF tend to use GPU-enabled Msieve polyselect, which despite an inferior algorithm, benefits from the ~100x speedup of GPUs. As I (and at least one other) don't have CUDA installed, I'd like to play around with CADO's polyselect.
I've done what I think is reasonable efforts to read all the documentation, but so far I've been unable to find out how to get the scripts to not even think about sieving/post-processing in the slightest. My parameters file has the following (polyselect params copied from the C190 example, save for I):
tasks.factorbase.run = false
tasks.sieve.run = false
tasks.filter.run = false
tasks.linalg.run = false
tasks.sqrt.run = false
tasks.polyselect.degree = 5
tasks.polyselect.P = 10000000
tasks.polyselect.admax = 5e7
tasks.polyselect.adrange = 5e5
tasks.polyselect.incr = 60
tasks.polyselect.nq = 1000
tasks.polyselect.nrkeep = 1000
tasks.I = 15
And yet, despite my best efforts, I get the following error when I launch cado-nfs.py:
Info:HTTP server: Using non-threaded HTTPS server
Debug:Generate Factor Base: Enter Task.__init__(factorbase)
Debug:Generate Factor Base: state = {}
Critical:Parameters: Required parameter alim not found under path tasks.sieve.factorbase
Traceback (most recent call last):
File "../cado-nfs.py", line 102, in <module>
path_prefix = [])
File "../scripts/cadofactor/cadotask.py", line 5105, in __init__
path_prefix=sievepath)
File "../scripts/cadofactor/cadotask.py", line 2387, in __init__
path_prefix=path_prefix)
File "../scripts/cadofactor/cadotask.py", line 987, in __init__
self.params = self.parameters.myparams(self.paramnames)
File "../scripts/cadofactor/cadoparams.py", line 746, in myparams
return self.parameters.myparams(keys, path)
File "../scripts/cadofactor/cadoparams.py", line 169, in myparams
self._convert_types(result, keys, splitpath, found_at_path)
File "../scripts/cadofactor/cadoparams.py", line 584, in _convert_types
raise KeyError(msg)
KeyError: 'Required parameter alim not found under path tasks.sieve.factorbase'
Why does cado-nfs insist on thinking about factorbase and sieving parameters when I will be doing nothing of the sort? In Msieve/Yafu I can select polyselect only with some variant of -np, -np1, -nps, -npr, and it doesn't require nor produce any sieving parameters whatsoever.
I'm reasonably certain that I could do just fine with some made up sieve parameters, but it still seems to me that I should be able to run individual parts of the overall algorithm without thinking about parts I know I won't be doing.
Of course there's a decent chance I've overlooked something, but a minor inquiry over at MF yielded nothing similar: http://mersenneforum.org/showthread.php?p=429303#post429303
Thank you for your consideration and assistance.
Bill
- [Cado-nfs-discuss] Fine tuned task/stage control, Bill Winslow, 03/17/2016
- Re: [Cado-nfs-discuss] Fine tuned task/stage control, paul zimmermann, 03/17/2016
- Message not available
- [Cado-nfs-discuss] Fwd: Fine tuned task/stage control, Bill Winslow, 03/18/2016
- Re: [Cado-nfs-discuss] Fwd: Fine tuned task/stage control, paul zimmermann, 03/18/2016
- Re: [Cado-nfs-discuss] Fwd: Fine tuned task/stage control, Bill Winslow, 03/18/2016
- [Cado-nfs-discuss] how to configure parameters, meng, 03/23/2016
- Re: [Cado-nfs-discuss] how to configure parameters, paul zimmermann, 03/23/2016
- Re: [Cado-nfs-discuss] how to configure parameters, meng, 03/30/2016
- Re: [Cado-nfs-discuss] how to configure parameters, paul zimmermann, 03/31/2016
- Re: [Cado-nfs-discuss] how to configure parameters, meng, 03/31/2016
