- To: cado-nfs-discuss@lists.gforge.inria.fr, Pierrick Gaudry <pierrick.gaudry@loria.fr>, Pankaj Charpe <charpe.pankajamol@gmail.com>
- Subject: Re: [Cado-nfs-discuss] FactorBaseFormat
- Date: Sat, 03 Feb 2018 13:00:10 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Yes.
Actually log(p) would be less misleading than degree(p)...
E.
On February 3, 2018 11:21:24 AM GMT+01:00, Pierrick Gaudry
<pierrick.gaudry@loria.fr> wrote:
>Hi,
>From an old README file I have somewhere in an old directory:
> Factor base file format:
> An entry is of the form:
> q:n1,n2: r1,r2,r3
> In the (frequent) case where n1,n2=1,0 this can be abridged with:
> q: r1,r2,r3
>Here, q is a irreducible or a irreducible power, ri are the
>corresponding
>roots and the contribution that must be subtracted at these positions
>is
> (n1-n2)*degree(p) (assuming smaller powers of this irreducible have
> alredy been taken care of). By position, we mean (a,b) such that a -
> b*ri = 0 mod q.
> The roots ri must be sorted in lexicographical order. If a root ri is
> greater or equal to q, it means that this is a projective root:
> subtracting q gives a root for the reciprocal polynomial (or
> equivalently, (1:(ri-q)) is the projective root).
> It is allowed to have several lines with the same q, but there must be
> only one line for a given (q,n1,n2) triple.
>Hopefully this is still valid in the version you are using.
>Regards,
>Pierrick
>On Sat, Feb 03, 2018 at 01:50:46PM +0530, Pankaj Charpe wrote:
>> Hi,
>> In factor base construction of cado-nfs we have this entry,
>> Factor Base format: q:n1,n2:r1,r2,r3
>> Can you please explain me what is these n1 and n2 ?. I will be very
>> thankful to you.
>> Thanks & Regards
>> Pankaj charpe
>> _______________________________________________
>> Cado-nfs-discuss mailing list
>> Cado-nfs-discuss@lists.gforge.inria.fr
>> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
Sent from my phone. Please excuse brevity and misspellings.
- [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/04/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/06/2018
