- To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] FactorBaseFormat
- Date: Mon, 5 Feb 2018 11:49:04 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=charpe.pankajamol@gmail.com; spf=Pass smtp.mailfrom=charpe.pankajamol@gmail.com; spf=None smtp.helo=postmaster@mail-pg0-f49.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I am clear with this now. Thanks for the explanation.
-Pankaj charpe
On Mon, Feb 5, 2018 at 1:28 AM, Emmanuel Thomé <Emmanuel.Thome@inria.fr> wrote:
On Sat, Feb 03, 2018 at 08:12:49PM +0530, Pankaj Charpe wrote:
> Thanks for the reply. I have studied your thesis. p and r (roots) are clear
> to me but I am not getting any explanation for those n1 and n2. Can you
> elaborate their use? I would really appreciate your reply. I also mailed
> via mailing list.
> Thanks & Regards
> Pankaj Charpe
Hi,
Let's say we have:
5: 1,3
25:2,1: 6,13
All pairs with a-1*b = 0 mod 5 or a-3*b = 0 mod 5 must receive a
contribution equal to round(log(5)).
Pairs with a-6*b = 0 mod 25 (which implies, in particular, a-1*b = 0 mod
5) receive an extra contribution of round(2*log(5))-round(1*log(5)).
A polynomial with this behaviour could be, for example (two distinct
examples below):
sage: ((x-6)*(x-13)+25).expand()
x^2 - 19*x + 103
sage: ((x-6)*(x-13)*ZZ['x'](GF(5)['x'].irreducible_element(2))+25).expand()
x^4 - 15*x^3 + 4*x^2 + 274*x + 181
And it can go on and on, as you lift to higher 5-adic roots. Unramified
roots in the p-adics will follow a simple pattern of this kind.
Now there are cases for which we need more information. Consider for
example the polynomial:
sage: ((x-6)*(x-1)+25).expand()
x^2 - 7*x + 31
For a-1*b = 0 mod 5, the 5-valuation goes from 0 to 2. We write this as:
5:2,0: 1
while for higher powers we would write:
25:3,2: 1,6
All sorts of situations are possible. The factor base format is meant to
express the different things that can occur in down-to-earth terms.
E.
> On Feb 3, 2018 5:30 PM, "Emmanuel Thomé" <emmanuel.thome@inria.fr> wrote:
> > Yes.
> > Actually log(p) would be less misleading than degree(p)...
> > E.
> > On February 3, 2018 11:21:24 AM GMT+01:00, Pierrick Gaudry <
> > pierrick.gaudry@loria.fr> wrote:
> > >Hi,
> > >From an old README file I have somewhere in an old directory:
> > > Factor base file format:
> > > An entry is of the form:
> > > q:n1,n2: r1,r2,r3
> > > In the (frequent) case where n1,n2=1,0 this can be abridged with:
> > > q: r1,r2,r3
> > >Here, q is a irreducible or a irreducible power, ri are the
> > >corresponding
> > >roots and the contribution that must be subtracted at these positions
> > >is
> > > (n1-n2)*degree(p) (assuming smaller powers of this irreducible have
> > > alredy been taken care of). By position, we mean (a,b) such that a -
> > > b*ri = 0 mod q.
> > > The roots ri must be sorted in lexicographical order. If a root ri is
> > > greater or equal to q, it means that this is a projective root:
> > > subtracting q gives a root for the reciprocal polynomial (or
> > > equivalently, (1:(ri-q)) is the projective root).
> > > It is allowed to have several lines with the same q, but there must be
> > > only one line for a given (q,n1,n2) triple.
> > >Hopefully this is still valid in the version you are using.
> > >Regards,
> > >Pierrick
> > >On Sat, Feb 03, 2018 at 01:50:46PM +0530, Pankaj Charpe wrote:
> > >> Hi,
> > >> In factor base construction of cado-nfs we have this entry,
> > >> Factor Base format: q:n1,n2:r1,r2,r3
> > >> Can you please explain me what is these n1 and n2 ?. I will be very
> > >> thankful to you.
> > >> Thanks & Regards
> > >> Pankaj charpe
> > >> _______________________________________________
> > >> Cado-nfs-discuss mailing list
> > >> Cado-nfs-discuss@lists.gforge.inria.fr
> > >> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
> > Sent from my phone. Please excuse brevity and misspellings.
- [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/04/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/06/2018
- Message not available
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/06/2018
