- To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] FactorBaseFormat
- Date: Mon, 5 Feb 2018 16:31:01 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=charpe.pankajamol@gmail.com; spf=Pass smtp.mailfrom=charpe.pankajamol@gmail.com; spf=None smtp.helo=postmaster@mail-pl0-f51.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
can you please provide a link to any reference paper to study this? It will be very helpful to me.
-pankaj
On Mon, Feb 5, 2018 at 4:27 PM, Pankaj Charpe <charpe.pankajamol@gmail.com> wrote:
okay. Now got it.Thank you very much for the valuable information.-pankajOn Mon, Feb 5, 2018 at 3:56 PM, Emmanuel Thomé <Emmanuel.Thome@inria.fr> wrote:On Mon, Feb 05, 2018 at 03:50:56PM +0530, Pankaj Charpe wrote:
> Yeah this my question. From your answer what I understood , 1 and 6 are
> roots for both mod 5 and mod 25.Then in order to get the distinct root we
> replace x by 1+5*x in case of mod 5. am I clear on this ?
> How this linear composition F(a*x+b) will help us to get the distinct roots
> ? Can you please elaborate it ?
f=(x-1)*(x-6)+125
solve for x in f(1+5*x) = 0 mod 125.
We're essentially doing hensel lifting step by step because this is a bit
nasty in this case.
E.
> -Pankaj
> On Mon, Feb 5, 2018 at 3:31 PM, Emmanuel Thomé <Emmanuel.Thome@inria.fr>
> wrote:
> > On Mon, Feb 05, 2018 at 03:20:13PM +0530, Pankaj Charpe wrote:
> > > Respected sir,
> > > I have one last doubt in understanding factor base construction.
> > > *In ffs/makefb.c*
> > This is related to ffs, which is now an obsolete algorithm.
> > But presumably what you describe holds nonetheless both for FFS and NFS.
> > > we find all the affine roots which satisfies the equation f(r)=0 modp .
> > > I am clear with all the procedure except one, when the multiplicity of
> > the
> > > root more than one then why we are finding linear compostion FF(x) :=
> > > F(phi1 * x + phi0) and recursively calling affine_roots.
> > > what is the need to find linear combination of a polinomial in case of
> > > multiplicity ? Can you please brief that else block. I will be very
> > > thankful to you.
> > I'm not sure I understand your question correctly.
> > If you have a multiple root, let's say in the case of (x-1)*(x-6)+125
> > which has the double root 1 mod 5, then clearly you need to replace x by
> > 1+5*x in order to tell apart the two distinct roots given by the
> > congruence classes 1 mod 25 and 6 mod 25.
> > E.
> > > Thanks & Regards
> > > Pankaj Charpe
> > > On Mon, Feb 5, 2018 at 11:49 AM, Pankaj Charpe <
> > > wrote:
> > > > I am clear with this now. Thanks for the explanation.
> > > > -Pankaj charpe
> > > > On Mon, Feb 5, 2018 at 1:28 AM, Emmanuel Thomé <
> > > > wrote:
> > > >> On Sat, Feb 03, 2018 at 08:12:49PM +0530, Pankaj Charpe wrote:
> > > >> > Thanks for the reply. I have studied your thesis. p and r (roots)
> > are
> > > >> clear
> > > >> > to me but I am not getting any explanation for those n1 and n2. Can
> > you
> > > >> > elaborate their use? I would really appreciate your reply. I also
> > mailed
> > > >> > via mailing list.
> > > >> > Thanks & Regards
> > > >> > Pankaj Charpe
> > > >> Hi,
> > > >> Let's say we have:
> > > >> 5: 1,3
> > > >> 25:2,1: 6,13
> > > >> All pairs with a-1*b = 0 mod 5 or a-3*b = 0 mod 5 must receive a
> > > >> contribution equal to round(log(5)).
> > > >> Pairs with a-6*b = 0 mod 25 (which implies, in particular, a-1*b = 0
> > mod
> > > >> 5) receive an extra contribution of round(2*log(5))-round(1*log(5)).
> > > >> A polynomial with this behaviour could be, for example (two distinct
> > > >> examples below):
> > > >> sage: ((x-6)*(x-13)+25).expand()
> > > >> x^2 - 19*x + 103
> > > >> sage: ((x-6)*(x-13)*ZZ['x'](GF(5)['x'].irreducible_element(2))+
> > 25)
> > > >> .expand()
> > > >> x^4 - 15*x^3 + 4*x^2 + 274*x + 181
> > > >> And it can go on and on, as you lift to higher 5-adic roots.
> > Unramified
> > > >> roots in the p-adics will follow a simple pattern of this kind.
> > > >> Now there are cases for which we need more information. Consider for
> > > >> example the polynomial:
> > > >> sage: ((x-6)*(x-1)+25).expand()
> > > >> x^2 - 7*x + 31
> > > >> For a-1*b = 0 mod 5, the 5-valuation goes from 0 to 2. We write this
> > as:
> > > >> 5:2,0: 1
> > > >> while for higher powers we would write:
> > > >> 25:3,2: 1,6
> > > >> All sorts of situations are possible. The factor base format is meant
> > to
> > > >> express the different things that can occur in down-to-earth terms.
> > > >> E.
> > > >> > On Feb 3, 2018 5:30 PM, "Emmanuel Thomé" <emmanuel.thome@inria.fr>
> > > >> wrote:
> > > >> > > Yes.
> > > >> > > Actually log(p) would be less misleading than degree(p)...
> > > >> > > E.
> > > >> > > On February 3, 2018 11:21:24 AM GMT+01:00, Pierrick Gaudry <
> > > >> > > pierrick.gaudry@loria.fr> wrote:
> > > >> > > >Hi,
> > > >> > > >From an old README file I have somewhere in an old directory:
> > > >> > > > Factor base file format:
> > > >> > > > An entry is of the form:
> > > >> > > > q:n1,n2: r1,r2,r3
> > > >> > > > In the (frequent) case where n1,n2=1,0 this can be abridged
> > with:
> > > >> > > > q: r1,r2,r3
> > > >> > > >Here, q is a irreducible or a irreducible power, ri are the
> > > >> > > >corresponding
> > > >> > > >roots and the contribution that must be subtracted at these
> > positions
> > > >> > > >is
> > > >> > > > (n1-n2)*degree(p) (assuming smaller powers of this
> > irreducible
> > > >> have
> > > >> > > > alredy been taken care of). By position, we mean (a,b) such
> > that
> > > >> a -
> > > >> > > > b*ri = 0 mod q.
> > > >> > > > The roots ri must be sorted in lexicographical order. If a
> > root ri
> > > >> is
> > > >> > > > greater or equal to q, it means that this is a projective
> > root:
> > > >> > > > subtracting q gives a root for the reciprocal polynomial (or
> > > >> > > > equivalently, (1:(ri-q)) is the projective root).
> > > >> > > > It is allowed to have several lines with the same q, but there
> > must
> > > >> be
> > > >> > > > only one line for a given (q,n1,n2) triple.
> > > >> > > >Hopefully this is still valid in the version you are using.
> > > >> > > >Regards,
> > > >> > > >Pierrick
> > > >> > > >On Sat, Feb 03, 2018 at 01:50:46PM +0530, Pankaj Charpe wrote:
> > > >> > > >> Hi,
> > > >> > > >> In factor base construction of cado-nfs we have this entry,
> > > >> > > >> Factor Base format:
> > q:n1,n2:r1,r2,r3
> > > >> > > >> Can you please explain me what is these n1 and n2 ?. I will be
> > very
> > > >> > > >> thankful to you.
> > > >> > > >> Thanks & Regards
> > > >> > > >> Pankaj charpe
> > > >> > > >> _______________________________________________
> > > >> > > >> Cado-nfs-discuss mailing list
> > > >> > > >> Cado-nfs-discuss@lists.gforge.inria.fr
> > > >> > > >> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-
> > discuss
> > > >> > > >https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
> > > >> > > Sent from my phone. Please excuse brevity and misspellings.
- Re: [Cado-nfs-discuss] FactorBaseFormat, (continued)
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/03/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/04/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Emmanuel Thomé, 02/05/2018
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pierrick Gaudry, 02/06/2018
- Message not available
- Re: [Cado-nfs-discuss] FactorBaseFormat, Pankaj Charpe, 02/06/2018
