Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process
- To: paul zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process
- Date: Tue, 24 Jul 2018 21:07:58 +0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-vk0-f41.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I've seen the params.c190, thank you for the suggestion. Now I change the command (increase bkmult and decrease threads) into something like this:
i'm still using the same poly as previous command.chun@chun-XPS-8300:~/Desktop/cado-nfs$ ./cado-nfs.py 1807082088687404805951656164405905566278102516769401349170127021450056662540244048387341127590812303371781887966563182013214880557 tasks.sieve.I=16 tasks.sieve.allow_largesq=true tasks.sieve.bkmult=1.2 tasks.polyselect.import=/home/chun/Desktop/c130\(2\)\ \[winner\].poly tasks.threads=6
Works fine until workunit adding (up to 84000)
Info:root: No database exists yet
Info:root: Created temporary directory /tmp/cado.p9oem_9f
Info:Database: Opened connection to database /tmp/cado.p9oem_9f/c130.db
Info:root: tasks.polyselect.threads = 2
Info:root: tasks.sieve.las.threads = 2
Info:root: slaves.scriptpath is /home/chun/Desktop/cado-nfs
Info:root: Command line parameters: ./cado-nfs.py 1807082088687404805951656164405905566278102516769401349170127021450056662540244048387341127590812303371781887966563182013214880557 tasks.sieve.I=16 tasks.sieve.allow_largesq=true tasks.sieve.bkmult=1.2 'tasks.polyselect.import=/home/chun/Desktop/c130(2) [winner].poly' tasks.threads=6
Info:root: If this computation gets interrupted, it can be resumed with ./cado-nfs.py /tmp/cado.p9oem_9f/c130.parameters_snapshot.0
Info:Server Launcher: Adding chun-XPS-8300 to whitelist to allow clients on localhost to connect
Info:HTTP server: Using non-threaded HTTPS server
Info:HTTP server: Using whitelist: localhost,chun-XPS-8300
Info:Complete Factorization: Factoring 1807082088687404805951656164405905566278102516769401349170127021450056662540244048387341127590812303371781887966563182013214880557
Info:HTTP server: serving at https://chun-XPS-8300:37199 (0.0.0.0)
Info:HTTP server: For debugging purposes, the URL above can be accessed if the server._only_registered_=False parameter is added
Info:HTTP server: You can start additional cado-nfs-client.py scripts with parameters: --server=https://chun-XPS-8300:37199 --certsha1=7ab56e5ad383768360274fc7fdd532aa0b2fde16
Info:HTTP server: If you want to start additional clients, remember to add their hosts to server.whitelist
Info:Client Launcher: Starting client id localhost on host localhost
Info:Client Launcher: Starting client id localhost+2 on host localhost
Info:Client Launcher: Starting client id localhost+3 on host localhost
Info:Client Launcher: Running clients: localhost (Host localhost, PID 2370), localhost+2 (Host localhost, PID 2373), localhost+3 (Host localhost, PID 2376)
Info:Polynomial Selection (size optimized): Skipping this phase, as we will import the final polynomial
Warning:Polynomial Selection (size optimized): some stats could not be displayed for polyselect1 (see log file for debug info)
Info:Polynomial Selection (root optimized): Starting
Info:Polynomial Selection (root optimized): Importing file /home/chun/Desktop/c130(2) [winner].poly
Info:Polynomial Selection (root optimized): New best polynomial from file /home/chun/Desktop/c130(2) [winner].poly: Murphy E = 2.35e-17
Info:Polynomial Selection (root optimized): Best polynomial previously found in /home/chun/Desktop/c130(2) [winner].poly has Murphy_E = 2.35e-17
Info:Polynomial Selection (root optimized): Imported polynomial, skipping this phase
Warning:Polynomial Selection (root optimized): some stats could not be displayed for polyselect2 (see log file for debug info)
Info:Generate Factor Base: Starting
Info:Generate Factor Base: Finished
Info:Generate Factor Base: Total cpu/real time for makefb: 40.49/8.95877
Info:Generate Free Relations: Starting
Info:Generate Free Relations: Found 406278 free relations
Info:Generate Free Relations: Finished
Info:Generate Free Relations: Total cpu/real time for freerel: 300.41/51.1111
Info:Lattice Sieving: Starting
Info:Lattice Sieving: We want 22129742 relation(s)
Info:Lattice Sieving: Adding workunit c130_sieving_711270-720000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_720000-730000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_730000-740000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_740000-750000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_750000-760000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_760000-770000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_770000-780000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_780000-790000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_790000-800000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_800000-810000 to database
Info:HTTP server: 127.0.0.1 Sending workunit c130_sieving_711270-720000 to client localhost
Info:HTTP server: 127.0.0.1 Sending workunit c130_sieving_720000-730000 to client localhost+2
Info:HTTP server: 127.0.0.1 Sending workunit c130_sieving_730000-740000 to client localhost+3
Info:Lattice Sieving: Adding workunit c130_sieving_810000-820000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_820000-830000 to database
Info:Lattice Sieving: Adding workunit c130_sieving_830000-840000 to database
first error shows up like this:
Error:Lattice Sieving: Program run on localhost+2 failed with exit code 137
Error:Lattice Sieving: Stderr output follows (stored in file /tmp/cado.p9oem_9f/c130.upload/c130_sieving_720000-730000.lqx6vejc.stderr0):
b'Killed\n'
Info:HTTP server: 127.0.0.1 Sending workunit c130_sieving_740000-750000 to client localhost+2
Info:Lattice Sieving: Resubmitting workunit c130_sieving_720000-730000 as c130_sieving_720000-730000#2
b'Killed\n'
then continues to this type of error:
Error:Lattice Sieving: Program run on localhost+2 failed with exit code 134
Error:Lattice Sieving: Stderr output follows (stored in file /tmp/cado.p9oem_9f/c130.upload/c130_sieving_740000-750000.qapv3c1q.stderr0):
b'code BUG() : condition r0 != std::numeric_limits<double>::lowest() failed in expand_at_root at /home/chun/Desktop/cado-nfs/sieve/logapprox.cpp:71 -- Abort\n*** Error: caught signal "Aborted"\n======= Backtrace: =========\n/tmp/cado.p9oem_9f/client/download/las() [0x4ad063]\n/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fd6c0d1e4b0]\n/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38) [0x7fd6c0d1e428]\n/lib/x86_64-linux-gnu/libc.so.6(abort+0x16a) [0x7fd6c0d2002a]\n/tmp/cado.p9oem_9f/client/download/las(_ZN29piecewise_linear_approximator14expand_at_rootEd+0x28b) [0x45ce9b]\n/tmp/cado.p9oem_9f/client/download/las(_ZN29piecewise_linear_approximator9logapproxEdd+0x144) [0x45e074]\n/tmp/cado.p9oem_9f/client/download/las(_ZN13lognorm_smartC1ERK13siever_configRK13cxx_cado_polyiRK14qlattice_basisii+0x14c) [0x45989c]\n/tmp/cado.p9oem_9f/client/download/las(_ZN10sieve_info16update_norm_dataEv+0xa5) [0x45f635]\n/tmp/cado.p9oem_9f/client/download/las(_Z16do_one_special_qR8las_infoR8nfs_workSt10shared_ptrI7nfs_auxER11thread_poolR14cxx_param_list+0x497) [0x474e27]\n/tmp/cado.p9oem_9f/client/download/las(main+0x2803) [0x454eb3]\n/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fd6c0d09830]\n/tmp/cado.p9oem_9f/client/download/las(_start+0x29) [0x4561a9]\nAborted (core dumped)\n'
then this keeps repeating.
I don't know what caused this, but unlike before, this has no suggestion in order to make it work (e.g: increase bkmult, and so on).
Thank you
2018-07-23 22:08 GMT+07:00 paul zimmermann <Paul.Zimmermann@inria.fr>:
> i've tried searching for bkmult parameter and it happens to be in the las
> command right?
> i wonder how i can adjust that parameter when i'm using cado-nfs.py command?
see parameters/factor/params.c190 in the git repository.
Paul
- [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process, canny georgina, 07/19/2018
- Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process, paul zimmermann, 07/19/2018
- Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process, canny georgina, 07/23/2018
- Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process, paul zimmermann, 07/23/2018
- Re: [Cado-nfs-discuss] [error] have enlarged memory and processor cores but failed to process, canny georgina, 07/24/2018
