- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] [error] Failed on the filtering step.
- Date: Thu, 26 Jul 2018 11:56:08 +0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-ua0-f179.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Previously, when I'm doing factoring on the c110 using imported polynomial, the problem about the large special-q is somehow solved using the allow_largesq=true option given at the end of the command. After that, sieving has been done up to 100% and then gone to filtering step (duplicate removal, and such..).
However, i found that it stopped halfway (during filtering step) as it shows something like this:
Info:Lattice Sieving: We want 4528085 relation(s)
Info:Lattice Sieving: Reached target of 4528085 relations, now have 4528093
Info:Lattice Sieving: Aggregate statistics:
Info:Lattice Sieving: Total number of relations: 4528093
Info:Lattice Sieving: Average J: 3794.19 for 110295 special-q, max bucket fill -bkmult 1.0,1s:1.448270
Info:Lattice Sieving: Total time: 240010s
Info:Filtering - Duplicate Removal, splitting pass: Starting
Info:Filtering - Duplicate Removal, splitting pass: No new files to split
Info:Filtering - Duplicate Removal, splitting pass: Relations per slice: 0: 2264054, 1: 2264039
Info:Filtering - Duplicate Removal, splitting pass: Total cpu/real time for dup1: 58.14/607.607
Info:Filtering - Duplicate Removal, splitting pass: Aggregate statistics:
Info:Filtering - Duplicate Removal, splitting pass: CPU time for dup1: 605.6s
Info:Filtering - Duplicate Removal, removal pass: Starting
Warning:Command: Process with PID 46510 finished with return code -6
Error:Filtering - Duplicate Removal, removal pass: Program run on server failed with exit code -6
Error:Filtering - Duplicate Removal, removal pass: Command line was: /home/chunnie/Desktop/Math3/cado-nfs/build/ubuntu/filter/dup2 -nrels 2264054 -renumber /tmp/cado.ky9t_u79/c110.renumber.gz /tmp/cado.ky9t_u79/c110.dup1//0/dup1.0.0000.gz > /tmp/cado.ky9t_u79/c110.dup2.slice0.stdout.2 2> /tmp/cado.ky9t_u79/c110.dup2.slice0.stderr.2
Error:Filtering - Duplicate Removal, removal pass: Stderr output follows (stored in file /tmp/cado.ky9t_u79/c110.dup2.slice0.stderr.2):
b'antebuffer set to /home/chunnie/Desktop/Math3/cado-nfs/build/ubuntu/utils/antebuffer\n[checking true duplicates on sample of 27170 cells]\nAllocated hash table of 2716969 entries (10Mb)\nConstructing the two filelists...\n1 files (1 new and 0 already renumbered)\nReading files already renumbered:\nReading new files (using 4 auxiliary threads for roots mod p):\nFatal error in renumber_get_first_index_from_p at /home/chunnie/Desktop/Math3/cado-nfs/utils/renumber.c:981\nIdeal (p, side) = (0xce83705, 0) is bigger that large prime bound 2^25\nFatal error in renumber_get_first_index_from_p at /home/chunnie/Desktop/Math3/cado-nfs/utils/renumber.c:981\nIdeal (p, side) = (0x48f7f67, 0) is bigger that large prime bound 2^25\nFatal error in renumber_get_first_index_from_p at /home/chunnie/Desktop/Math3/cado-nfs/utils/renumber.c:981\nIdeal (p, side) = (0x409c88f, 1) is bigger that large prime bound 2^26\nFatal error in renumber_get_first_index_from_p at /home/chunnie/Desktop/Math3/cado-nfs/utils/renumber.c:981\nIdeal (p, side) = (0x409c88f, 1) is bigger that large prime bound 2^26\n'
Traceback (most recent call last):
File "./cado-nfs.py", line 122, in <module>
factors = factorjob.run()
File "./scripts/cadofactor/cadotask.py", line 5754, in run
last_status, last_task = self.run_next_task()
File "./scripts/cadofactor/cadotask.py", line 5829, in run_next_task
return [task.run(), task.title]
File "./scripts/cadofactor/cadotask.py", line 3560, in run
raise Exception("Program failed")
Exception: Program failed
Thank you
- [Cado-nfs-discuss] [error] Failed on the filtering step., canny georgina, 07/26/2018
- Re: [Cado-nfs-discuss] [error] Failed on the filtering step., paul zimmermann, 07/26/2018
- Message not available
- Re: [Cado-nfs-discuss] [error] Failed on the filtering step., canny georgina, 07/26/2018
- [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step., canny georgina, 07/26/2018
- Re: [Cado-nfs-discuss] Fwd: [error] Failed on the filtering step., paul zimmermann, 07/26/2018
