- To: Pierrick Gaudry <pierrick.gaudry@loria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] [error] caused by a larger special-q
- Date: Tue, 24 Jul 2018 13:36:07 +0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-vk0-f48.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I have tried your suggestion, and it works, thank you very much. Now, I'm able to resume the previous work.
2018-07-24 12:32 GMT+07:00 Pierrick Gaudry <pierrick.gaudry@loria.fr>:
The README says:
If you want to import already computed relations, use:
tasks.sieve.import=foo
where "foo" is the name of the relation file to be imported (in CADO-NFS
format). Alternatively you can do:
tasks.sieve.import=@foo
where "foo" is a file containing several names of relation files, one file
name per line.
But you used:
tasks.sieve.import=@/tmp/cado.5tpo3b5l/c110.upload/
where c110.upload is a directory name. You should create a file
containing the names of relations files.
Pierrick
- [Cado-nfs-discuss] [error] caused by a larger special-q, canny georgina, 07/23/2018
- Re: [Cado-nfs-discuss] [error] caused by a larger special-q, Pierrick Gaudry, 07/23/2018
- Re: [Cado-nfs-discuss] [error] caused by a larger special-q, canny georgina, 07/23/2018
- Re: [Cado-nfs-discuss] [error] caused by a larger special-q, paul zimmermann, 07/23/2018
- Re: [Cado-nfs-discuss] [error] caused by a larger special-q, canny georgina, 07/24/2018
- Re: [Cado-nfs-discuss] [error] caused by a larger special-q, Pierrick Gaudry, 07/24/2018
