cado-nfs - [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
  • Date: Fri, 19 Apr 2019 13:14:43 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=dclarke@blastwave.org; spf=None smtp.mailfrom=dclarke@blastwave.org; spf=None smtp.helo=postmaster@atl4mhob05.registeredsite.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
This is very odd given that two previous tests worked fine :
nix$
nix$ /usr/bin/time -p ./cado-nfs.py 18446744073709551601131234567890124193
Traceback (most recent call last):
File "./cado-nfs.py", line 64, in <module>
parameters, db = toplevel_params.get_cooked_parameters()
File "./scripts/cadofactor/toplevel.py", line 1151, in get_cooked_parameters
self.set_N_paramfile_workdir()
File "./scripts/cadofactor/toplevel.py", line 634, in set_N_paramfile_workdir
self.args.parameters = self.find_default_parameter_file()
File "./scripts/cadofactor/toplevel.py", line 183, in find_default_parameter_file
" for %s (tried %s)" % (attempts[0], ", ".join(attempts)))
Command exited with non-zero status 1
real 0.08
user 0.08
sys 0.00
nix$
Any thoughts ?
Dennis
