Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
- Date: Sun, 21 Apr 2019 19:08:45 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dclarke@blastwave.org; spf=None smtp.mailfrom=dclarke@blastwave.org; spf=None smtp.helo=postmaster@atl4mhob14.registeredsite.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On 4/19/19 4:32 PM, Emmanuel Thomé wrote:
Parameter files are provided only for 60 digits and up (and also for 30
digits, but that is an exception we use only for testing). It would be
feasible to fill this gap, but in this size range, qs is obviously a
better alternative.
I agree that the error message could certainly be more polite...
Seems really big numbers are a problem also :
nix$ /usr/bin/time -p /usr/bin/nice -n +19 ./cado-nfs.py 46979456894555104376348061128818736834683233445508426434910891216933137932795235258532415417078413982950462649291680116415533192303358215736593956417994750205257150937406422457529901628917888316357401 -t 1
Info:root: Using default parameter file ./parameters/factor/params.c200
Info:root: No database exists yet
Info:root: Created temporary directory /var/tmp/dclarke/cado.sj7y78j3
Info:Database: Opened connection to database /var/tmp/dclarke/cado.sj7y78j3/c200.db
Info:root: Set tasks.threads=1 based on --server-threads 1
Info:root: tasks.threads = 1 [via tasks.threads]
Info:root: tasks.polyselect.threads = 1 [via tasks.polyselect.threads]
Info:root: tasks.sieve.las.threads = 1 [via tasks.sieve.las.threads]
Info:root: tasks.linalg.bwc.threads = 1 [via tasks.threads]
Info:root: tasks.sqrt.threads = 1 [via tasks.threads]
Info:root: slaves.scriptpath is /home/dclarke/local/build/cado-nfs
Info:root: Command line parameters: ./cado-nfs.py 46979456894555104376348061128818736834683233445508426434910891216933137932795235258532415417078413982950462649291680116415533192303358215736593956417994750205257150937406422457529901628917888316357401 -t 1
Info:root: If this computation gets interrupted, it can be resumed with ./cado-nfs.py /var/tmp/dclarke/cado.sj7y78j3/c200.parameters_snapshot.0
Info:Server Launcher: Adding nix to whitelist to allow clients on localhost to connect
Info:HTTP server: Using non-threaded HTTPS server
Info:HTTP server: Using whitelist: localhost,nix
Critical:Parameters: Required parameter qmin not found under path tasks.polyselect
Traceback (most recent call last):
File "./cado-nfs.py", line 116, in <module>
path_prefix = [])
File "./scripts/cadofactor/cadotask.py", line 5605, in __init__
path_prefix=polyselpath)
File "./scripts/cadofactor/cadotask.py", line 2202, in __init__
path_prefix=path_prefix)
File "./scripts/cadofactor/cadotask.py", line 1496, in __init__
File "./scripts/cadofactor/cadotask.py", line 1056, in __init__
self.params = self.parameters.myparams(self.paramnames)
File "./scripts/cadofactor/cadoparams.py", line 789, in myparams
return self.parameters.myparams(keys, path)
File "./scripts/cadofactor/cadoparams.py", line 169, in myparams
self._convert_types(result, keys, splitpath, found_at_path)
File "./scripts/cadofactor/cadoparams.py", line 626, in _convert_types
raise KeyError(msg)
KeyError: 'Required parameter qmin not found under path tasks.polyselect'
Command exited with non-zero status 1
real 2.92
user 0.51
sys 0.08
nix$
However quite large seems to be no problem.
Factoring 6513516734600035718300327211250928237178281758494417357560086828416863929270451437126021949850746389
seems to work fine.
nix$
nix$ /usr/bin/time -p /usr/bin/nice -n +19 ./cado-nfs.py 6513516734600035718300327211250928237178281758494417357560086828416863929270451437126021949850746389 -t 1
Info:root: Using default parameter file ./parameters/factor/params.c100
Info:root: Created temporary directory /var/tmp/dclarke/cado.ibomf2ji
Info:Database: Opened connection to database /var/tmp/dclarke/cado.ibomf2ji/c100.db
Info:root: Command line parameters: ./cado-nfs.py 6513516734600035718300327211250928237178281758494417357560086828416863929270451437126021949850746389 -t 1
Info:root: If this computation gets interrupted, it can be resumed with ./cado-nfs.py /var/tmp/dclarke/cado.ibomf2ji/c100.parameters_snapshot.0
Info:Linear Algebra: mksol: N=1000 ; ETA (N=3000): Sun Apr 21 23:06:01 2019 [0.036 s/iter]
Info:Linear Algebra: mksol: N=1000 ; ETA (N=3000): Sun Apr 21 23:07:49 2019 [0.072 s/iter]
Info:Linear Algebra: mksol: N=977 ; ETA (N=3000): Sun Apr 21 23:09:39 2019 [0.109 s/iter]
Info:Quadratic Characters: Starting
Info:Square Root: Starting
Info:Square Root: Creating file of (a,b) values
Info:Square Root: finished
Info:Square Root: Factors: 11 109 5419 79481 12612868752726608676534011211161792825225468670101915251045116250013903143003646733006649
Info:Polynomial Selection (size optimized): Aggregate statistics:
Info:Polynomial Selection (size optimized): potential collisions: 5781.44
Info:Polynomial Selection (size optimized): raw lognorm (nr/min/av/max/std): 5771/33.040/38.091/38.930/0.691
Info:Polynomial Selection (size optimized): optimized lognorm (nr/min/av/max/std): 5771/32.690/36.787/38.920/0.977
Info:Polynomial Selection (size optimized): Total time: 88.23
Info:Polynomial Selection (root optimized): Aggregate statistics:
Info:Polynomial Selection (root optimized): Total time: 51.93
Info:Polynomial Selection (root optimized): Rootsieve time: 51.66
Info:Generate Factor Base: Total cpu/real time for makefb: 0.66/0.671431
Info:Generate Free Relations: Total cpu/real time for freerel: 17.54/17.1051
Info:Lattice Sieving: Aggregate statistics:
Info:Lattice Sieving: Total number of relations: 2434823
Info:Lattice Sieving: Average J: 1024 for 87005 special-q, max bucket fill -bkmult 1.0,1s:1.058450
Info:Lattice Sieving: Total time: 4755.63s
Info:Filtering - Duplicate Removal, splitting pass: Total cpu/real time for dup1: 3.36/8.66293
Info:Filtering - Duplicate Removal, splitting pass: Aggregate statistics:
Info:Filtering - Duplicate Removal, splitting pass: CPU time for dup1: 8.399999999999999s
Info:Filtering - Duplicate Removal, removal pass: Total cpu/real time for dup2: 20.4/23.1955
Info:Filtering - Duplicate Removal, removal pass: Aggregate statistics:
Info:Filtering - Duplicate Removal, removal pass: CPU time for dup2: 19.399999999999995s
Info:Filtering - Singleton removal: Total cpu/real time for purge: 13.31/16.1994
Info:Filtering - Merging: Total cpu/real time for merge: 71.23/75.7246
Info:Filtering - Merging: Total cpu/real time for replay: 6.26/5.70511
Info:Linear Algebra: Total cpu/real time for bwc: 351.56/356.6
Info:Linear Algebra: Aggregate statistics:
Info:Linear Algebra: Krylov: WCT time 186.49, iteration CPU time 0.03, COMM 0.0, cpu-wait 0.0, comm-wait 0.0 (6000 iterations)
Info:Linear Algebra: Lingen CPU time 11.37, WCT time 11.63
Info:Linear Algebra: Mksol: WCT time 106.86, iteration CPU time 0.03, COMM 0.0, cpu-wait 0.0, comm-wait 0.0 (3000 iterations)
Info:Quadratic Characters: Total cpu/real time for characters: 6.32/6.81588
Info:Square Root: Total cpu/real time for sqrt: 0.02/0.017874
Info:HTTP server: Shutting down HTTP server
Info:Complete Factorization: Total cpu/elapsed time for entire factorization: 14040.3/5464.46
Info:root: Cleaning up computation data in /var/tmp/dclarke/cado.ibomf2ji
real 5467.48
user 497.84
sys 5.54
nix$
So that is impressive.
Regarding one of your earlier e-mails, don't mix "cmake" and "make". The
steps called "Configure" and "Compile" must be followed in order, and
then "Install" if you so wish.
Right. Thank you. sorted that out. Will there be a tarball release at some point or just git ?
Dennis
- [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Dennis Clarke, 04/19/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Emmanuel Thomé, 04/19/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Dennis Clarke, 04/22/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Emmanuel Thomé, 04/22/2019
