Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
- To: Dennis Clarke <dclarke@blastwave.org>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??
- Date: Mon, 22 Apr 2019 01:33:18 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Sun, Apr 21, 2019 at 07:08:45PM -0400, Dennis Clarke wrote:
> > Regarding one of your earlier e-mails, don't mix "cmake" and "make". The
> > steps called "Configure" and "Compile" must be followed in order, and
> > then "Install" if you so wish.
> Right. Thank you. sorted that out. Will there be a tarball release at some
> point or just git ?
Forgot to answer that one.
Latest "release" of cado-nfs was fall 2017 iirc. It would probably make
sense that we strive to make a newer one by the end of the year. Don't
take it as any sort of promise though.
E.
- [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Dennis Clarke, 04/19/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Emmanuel Thomé, 04/19/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Dennis Clarke, 04/22/2019
- Re: [Cado-nfs-discuss] RuntimeError: no parameter file found for c38 (tried c38, c40) ??, Emmanuel Thomé, 04/22/2019
