cado-nfs - Re: [Cado-nfs-discuss] A little light relief
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] A little light relief
  • Date: Tue, 3 Sep 2019 15:40:02 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
On Fri, Aug 23, 2019 at 12:04:47PM +0100, Paul Leyland wrote:
> I'm sure you are all tired of hearing of bugs so I thought I'd share this
> logging output from the siever:
> Info:Lattice Sieving: Marking workunit GCW11244-_sieving_65930000-65940000
> as ok (0.0% => ETA Wed Feb 15 18:46:52 2023)
> Info:Lattice Sieving: Marking workunit GCW11244-_sieving_65920000-65930000
> as ok (0.0% => ETA Wed Jun 2 23:18:51 2021)
> Info:Lattice Sieving: Marking workunit GCW11244-_sieving_65910000-65920000
> as ok (0.0% => ETA Wed Nov 11 18:48:35 2020)
> That's what I like to see. At the rate that the ETA is decreasing, the
> computation should be finished some time in the third millennium BC!
Well, why not ?
You seem to surmise that the ETA would decrease linearly. That is not
true. We want the ETA to converge to the real finish time, and I see
above no indication that it won't be the case. Having an ETA that is way
way off at the beginning is totall expected. Indeed, it is computed based
on a linear fit of the computation progress *thus far*, e.g. with the
formula:
ETA = now + (work left to do) / (work already done) * (time spent thus
far).
E.
