- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] A little light relief
- Date: Tue, 3 Sep 2019 18:07:16 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=paul.leyland@gmail.com; spf=Pass smtp.mailfrom=paul.leyland@gmail.com; spf=None smtp.helo=postmaster@mail-wm1-f54.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
You seem to surmise that the ETA would decrease linearly. That is not
true. We want the ETA to converge to the real finish time, and I see
above no indication that it won't be the case. Having an ETA that is way
way off at the beginning is totall expected. Indeed, it is computed based
on a linear fit of the computation progress *thus far*, e.g. with the
formula:
I suspect that someone doesn't understand British ironic humour.
- Re: [Cado-nfs-discuss] A little light relief, Emmanuel Thomé, 09/03/2019
- Re: [Cado-nfs-discuss] A little light relief, Paul Leyland, 09/03/2019
