cado-nfs - Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage
  • To: David Willmore <davidwillmore@gmail.com>
  • Cc: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage
  • Date: Mon, 9 Dec 2019 14:46:07 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Mon, Dec 09, 2019 at 06:27:52AM -0500, David Willmore wrote:
> Upon restarting the cado-nfs.py script with the location of the
> recovery parameter file, I was told that there was a short read from
> the .prep file. Moving that out of the way and restarting resulted in
> the same error.
Can you give the exact error message please ? You can probably find it in
files called c155.bwc.std*
You might want to try to remove the cache directories c155.bwc/c155.*x*/
; those are likely to contain files that were written incompletely.
E.
