cado-nfs - Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage
  • To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
  • Cc: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage
  • Date: Mon, 9 Dec 2019 14:09:33 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=davidwillmore@gmail.com; spf=Pass smtp.mailfrom=davidwillmore@gmail.com; spf=None smtp.helo=postmaster@mail-qv1-f46.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Thank you for your response. The stderr from that was:
Writing balancing data to c155.sparse.4x6.bin
write(cached matrix file): No space left on device
/home/willmore/factoring/cado-nfs-2.3.0/build/blade/linalg/bwc/prep:
exited with status 1
aborted on subprogram error at
/home/willmore/factoring/cado-nfs-2.3.0/build/blade/linalg/bwc/bwc.pl
line 512.
...propagated at
line 1406.
> From Paul.Zimmerman@inria.fr
> you can restart the linear algebra directly by running the bwc.pl command
> at the top of c155.bwc.stdout.1.
> All files of the same type should have the same size. If one is short,
> just remove it (or move it to another place) and restart the bwc.pl command.
Nice to hear from you again, Paul. It's been a long time.
That seems to have done it. I've moved all of those files out as they
were of several different lengths and restarted the command.
It's running now. Will this complete the factorization or will I need
to manually perform any other steps after this?
Thank you both for your help! I'll share my results with the group if
anyone is interested.
Cheers,
David Willmore
On Mon, Dec 9, 2019 at 8:46 AM Emmanuel Thomé <Emmanuel.Thome@inria.fr> wrote:
> On Mon, Dec 09, 2019 at 06:27:52AM -0500, David Willmore wrote:
> > Upon restarting the cado-nfs.py script with the location of the
> > recovery parameter file, I was told that there was a short read from
> > the .prep file. Moving that out of the way and restarting resulted in
> > the same error.
> Can you give the exact error message please ? You can probably find it in
> files called c155.bwc.std*
> You might want to try to remove the cache directories c155.bwc/c155.*x*/
> ; those are likely to contain files that were written incompletely.
> E.
